Subframe Puzzler
Posted: Sat Jun 08, 2019 1:46 pm
by xvivalve
What model is this off then?
It doesn’t look to have been modified...
Re: Subframe Puzzler
Posted: Sat Jun 08, 2019 3:35 pm
by geeksteve
Looks like my 1500 subframe, unless I'm missing something?
Posted: Sat Jun 08, 2019 4:01 pm
by Jod Clark
1500 auto :bluewave:
Posted: Sat Jun 08, 2019 5:25 pm
by xvivalve
Since when have 1500s had twin bolted mounts at the front of the engine?
Posted: Sat Jun 08, 2019 5:37 pm
by Jod Clark
Same shape mount as the 1850, two bolts to the subframe, one to the donk.
Posted: Sat Jun 08, 2019 5:54 pm
by xvivalve
Could have sworn they were single bolt, both sides...must be age catching up with me...or the drugs...or both!
Posted: Sat Jun 08, 2019 5:56 pm
by xvivalve
Question is then, where did I get it from??? I've had it sitting in my yard since goodness knows when on the misapprehension it was Sprint!
Anyone need a 1500 subframe?
Posted: Sat Jun 08, 2019 7:34 pm
by TrustNo1
Its only for the 1500 Auto, the subframe for a 1500 manual as the extra A shape at the rear to take the gearbox mount doesn't it?
Posted: Sat Jun 08, 2019 9:34 pm
Only just seen this, Jod and Julian are perfectly correct, it's a 1500 Auto subframe and unique to that model. I have one just like it lying around in my yard from the white car I broke last year. I'd not seen one before that turned up either! I'll take it off your hands if you like, it's one I can safely cut about for my Vauxhall conversions and it'll never be missed by someone needing a slant frame.
Posted: Sat Jun 08, 2019 9:39 pm
by triumphdolomiteuk
TrustNo1 wrote: Sat Jun 08, 2019 7:34 pm Its only for the 1500 Auto, the subframe for a 1500 manual as the extra A shape at the rear to take the gearbox mount doesn't it?
Yes it does, quite right.
Posted: Sun Jun 09, 2019 7:19 am
by Jod Clark
Also suitable for 1500 O/D, even though they usually have the triangular extension which isn't actually needed with the overdrive gearbox.
Posted: Sun Jun 09, 2019 10:38 am
by Steve28
I would take it as a spare if nearer or if i get down that way some time soon.
