Bumpa wrote: ↑Tue Jul 23, 2019 7:24 pm I would use a Revotec thermo switch in the top hose.
Notwithstanding the issue of the bottom hose being the best place to determine, from a simple threshold temperature measurement, whether the electric fan needs to be on or off (a different issue from any nugatory attempt to actually control engine temperature with a fan), there are far cheaper ways to do this.
I'm using an NTC sender that was £4 off eBay in a hose adapter that was a fiver off Aliexpress and a simple voltage comparator module with a built in relay like those that are £3.45 off eBay (mine's a two channel one that was supposed to have on/off hysteresis, but due to an issue in translation turned out to be 4 comparators used as a window controller - but we have a drill to fix the PCB with).
The comparator lets me set an on temperature (currently from about 40 to 120C, but I may narrow that a bit) with one pot. But I have modified it so another pot sets the off temperature as an offset to that, which can be as little as zero offset. But that's arranged so it doesn't change the on temperature. Those mods cost me another sick squid - but I have 2 pots, 24 diodes, and about 290 1/4 watt resistors left over.
I've mounted the module and two pots in a box (which came from Maplins and I think cost more than any other single item), which is currently double sided sticky taped to the front parcel shelf so I can set it up. I still need to add a cap to kill the noise picked up in the lead to the sender jittering the relay at low hysteresis. And when it stops raining I may re-cable with screened twinax rather than the twisted pair I have in.
There is point on this issue about the mechanical fan taking power more or less all the time. That is that once the airspeed of the car is greater than the pitch speed of the fan blade, the angle of attack between the blade and the airstream stops being positive, and it switches from transferring power into the airstream to taking power out of it. I'm not sure what that speed is for the mechanical fan and torque drive, but it's possible to estimate that for an electric fan from its CFM value (if you have one that's true) and its CSA - the zero angle airspeed should be fairly close to the free airspeed the fan gives.
That angle of attack limit to the airspeed that a (more or less) constant speed electric fan can have an affect within (and the square root relation between the convective thermal coefficient of air and airspeed limits its effective range further) is one of the reasons engine temperature control still needs the thermostat, and the fan can't really take over that job.
