Page 1 of 2
Sprint rear hub removal
Posted: Tue Sep 03, 2019 5:42 pm
by GrahamFountain
I've got a busted stud on the rear wheel and the garage are struggling to get the hub off to replace. Any tricks or tips on how it's nb est done.
Re: Sprint rear hub removal
Posted: Tue Sep 03, 2019 6:53 pm
by xvivalve
Remove it with the halfshaft and then use a big press; they normally go with a bang!
Posted: Tue Sep 03, 2019 7:55 pm
by GrahamFountain
Ta, I'll pass that on.
Posted: Tue Sep 03, 2019 8:42 pm
by Richard the old one
Do you have to take the hub off to replace a rear hub stud on a sprint as on the 1500 and 1850 you can just tap out the wheel studs towards the brake back plate?
Posted: Tue Sep 03, 2019 10:56 pm
by xvivalve
Richard the old one wrote: Tue Sep 03, 2019 8:42 pm Do you have to take the hub off to replace a rear hub stud on a sprint as on the 1500 and 1850 you can just tap out the wheel studs towards the brake back plate?
Yes, you do.
Posted: Wed Sep 04, 2019 3:07 pm
by Mad Mart
xvivalve wrote: Tue Sep 03, 2019 10:56 pm
Yes, you do.
You can peel the cover on the back of the hub to remove the studs but it won't look so pretty afterwards.
Posted: Thu Sep 05, 2019 7:43 am
by GrahamFountain
Mad Mart wrote: Wed Sep 04, 2019 3:07 pm
I thought it was recommended to press the studs in, not pull them in with nuts, etc., like with Fords. Wouldn't that be hard in situ?
Posted: Fri Sep 13, 2019 9:56 pm
by GrahamFountain
Unfortunately the guy who owns the garage doesn't want to pull the shaft and press the hub off, he wants to use a hub puller. Does anybody have a recommendation for a tool? I see there are Herald/Spitfire ones, and I know that's the same PCD. Would one of them fit, or is there another option?
Posted: Fri Sep 13, 2019 10:43 pm
by xvivalve
Churchill made one up to the job, but with a conventional 3 leg he'd be wasting his time...and most likely the puller too!
Posted: Fri Sep 13, 2019 10:47 pm
by xvivalve
Posted: Sat Sep 14, 2019 5:39 am
by cliftyhanger
If he uses a non-churchill type hub puller I would say he will 99% scarp the hub (though not admit to it)
Trouble is that with the churchill puller you need all 4 studs in position. Catch 22.
Take it somewhere else?
Posted: Sat Sep 14, 2019 9:32 am
by xvivalve
cliftyhanger wrote: Sat Sep 14, 2019 5:39 am
Second that.
Posted: Sat Sep 14, 2019 10:44 am
by GrahamFountain
xvivalve wrote: Sat Sep 14, 2019 9:32 am
Second that.
Yeah, I guess. Thing is, the garage is opposite work. So it's real convenient for smaller jobs can be done in a day. And he's done me more than a few favours with stuff no one else would do.
I wondered about one of these with three legs on the smaller diameter ring: https://www.ebay.co.uk/itm/Universal-wh ... 1438.l2649. Should be better than a 3 leg puller that latches behind the hub flange.
Posted: Sat Sep 14, 2019 10:53 am
by GrahamFountain
xvivalve wrote: Fri Sep 13, 2019 10:47 pm Previous discussion:
https://forum.triumphdolomite.co.uk/vie ... el#p267821
The suggestion there is that the Herald one needs modifying. At £100 (inc p&p and some other bits) I'm not sure its a cost effective option compared to pulling the halfshaft. But might it fit with a wheel spacer on the hub first, and if so, how thick?
Posted: Sat Sep 14, 2019 12:24 pm
by Mad Mart
xvivalve wrote: Tue Sep 03, 2019 6:53 pm Remove it with the halfshaft and then use a big press; they normally go with a bang!
This is the way I've always done mine. I can't see you doing it any other way unless you have the correct puller.
