We've been looking at a pair of carbs; on an early Sprint and the odd thing is that only the front carb; has a fuel overflow drainage pipe. There is no facility fitted for the overflow on the rear carb;
The Parts book only quotes Qty 1-off for the external overflow pipe and even the Sprint workshop manual says in the section on carb; overhaul " Remove the pipe from the front carb; only "
Yet my 1850 of a similar vintage has fuel overflow pipes on both carbs; Why the difference ?
Surely its not penny pinching of the worst order on the Sprint is it ?
Ta.
Sprint SU carbs; anomaly.
- tangocharlie1
Re: Sprint SU carbs; anomaly.
Cannot answer your question to why. But you are certainly correct. My 1973 sprint only has the overflow on the front carb.
1973 Triumph Dolomite Sprint
1972 Triumph Stag
1973 Triumph TR6
1972 Triumph Stag
1973 Triumph TR6
