It is currently Mon Apr 19, 2021 5:52 am
Post new topic Reply to topic  [34 posts ]  Go to pagePrevious123
PostPosted:Thu Feb 18, 2021 11:55 am
Didn't know any dolys had the horn button in the steering wheel.
Almost like it was just a joke or something..
PostPosted:Thu Feb 18, 2021 12:39 pm
It must have lost something in the translation.
PostPosted:Thu Feb 18, 2021 2:27 pm
I think someone has mistranslated "small chassis cars" ie Herald, Spitfire and their derivatives, as "small saloons" the less well known term for the Dolomite range and it's variants and predecessors.
All the small chassis cars have the horn push in the steering wheel (with the exception, I think, of the 1500 Spit) and need some sort of earth connection across the lower coupling, which, IIRC, originally comprised a cable between the 2 clamp bolts. Also a second, oft mislaid, earth for the (rubber mounted) rack body.
Whereas the Dolomite range mostly has it's horn push on the indicator switch and switched power, rather than the switched earth of the Herald et al. Though i'm not sure how the 1300FWD one works.
Apologies if I'm teaching Granny to suck eggs here!
'72 Triumph 1500FWD in Slate Grey
PostPosted:Thu Feb 18, 2021 9:34 pm
James
A very timely topic for I have several knuckles sitting here on my bench all waiting for me to rebuild.
Each has a centre disc which measures 0.230, close to ¼ and certainly not 3/16.
I would be most interested in sourcing some longer bolts, longer than the one measured here, 0.9845 or near enough to 1 inch for then I would rebuild mine, Loctite the threads and then wire them as was originally done.
Robert
Display posts from previous: Sort by
