It is currently Sun Apr 18, 2021 1:50 pm
Post new topic Reply to topic  [1 post ]
PostPosted:Thu Oct 31, 2019 4:49 pm
Hi all with a heavy heart I've been putting it off but with moving and little one and limited time it's best to sell onto someone who will finish her.
-Shell with escort mk2 stand and tank, welded seat rails and strut brace (shell has been modified to take a vauxhall redtop engine and rx8 6speed gearbox - logbooked has engine code changed to match)
-rollcage bolted in
-Brand new gaz height and ride adjustable shocks with updated springs
-sprintspeed bubble arch kit
-2x sparco pro2000 bucket seats
-Polybushes front and back
- redtop engine (head is off engine bottom end has been rebuilt with new bearings and seals) also comes with new head gasket kit, timing belt,water pump and tensioner and head rebuilt kit.
Spare exhaust camshaft
-rx8 6speed gearbox (15mm machined off bellhousing plus proper adaptor plate)
plate)
-yukspeed front bowl winged sump for 0degrees
-MBE ecu and loom to run carbs on redtop engine
-sprint axle and modified front sub frame
-4pot princess calipers
-clio 2 power steering column and controller
-rolling jig which car is already on
The shell will need some fabrication but had new sills (front panel and wings removed so will require new dolomite club sell grp ones good quality) . Has had the engine , gearbox mocked up with solid engine mounts in place.
Theres loads of spares that I haven't mentioned but viewing is recommended.
£2750ono
Any questions please PM me and i can email photos
Display posts from previous: Sort by
