overdrive?
Posted: Sat May 16, 2020 8:33 pm
by whydidistartthis
quick question.
If i remove the overdrive sump plate, How much oil should I expect to find?
Want to check the filters. But can not find anything that says drain gearbox first.
Thanks in advance..
Re: overdrive?
Posted: Sat May 16, 2020 10:08 pm
by Bumpa
As far as I know you will empty the whole gearbox if you take the plate off.
Re: overdrive?
Posted: Sat May 16, 2020 11:58 pm
by cleverusername
whydidistartthis wrote: Sat May 16, 2020 8:33 pm quick question.
Thanks in advance..
Drain the gearbox, they have a common supply. You will also need a special tool to take the high pressure filters out, it is a bit like the tool you use to change the discs on an angle grinder. Basically you need something with two prongs, at the correct spacing, to turn them. You can an adjustable version of an angle grinder locking tool and it will undo the high pressure filters.
Why are you checking the overdrive?
Re: overdrive?
Posted: Sun May 17, 2020 2:50 pm
by whydidistartthis
cleverusername wrote: Sat May 16, 2020 11:58 pm
Thanks in advance..
checking the overdrive, as I am getting the effect of clutch slip. But if i pull away enthusiastically I can still warm the rear tyres up.
Doesn't do it all the time. usually on the 2nd to 3rd gear change. Not doing it consistently enough to fully diagnose.
Clutching at straws a bit.
