Servo success, gear gaiter woes
Posted: Sat Jun 06, 2020 7:44 pm
by cleverusername
Good news, bad news. Isn't that always the way with old cars?
The good news is the Sprint servo I got off ebay will work with the 1500 master cylinder and clutch master. I tested it with the engine running and it works.
However I found a problem, the 1500 metal mount for the rubber gear gaiter fouls the Sprint gear selector mechanism and you get a nice clonk when the engine is running.
So I either need the Sprint item, have to modify the 1500 one or make one from scratch. Has anyone got one they would be willing to sell or made such a modification themselves?
Re: Servo success, gear gaiter woes
Posted: Sat Jun 06, 2020 8:53 pm
by new to this
cleverusername wrote: Sat Jun 06, 2020 7:44 pm Good news, bad news. Isn't that always the way with old cars?
Hi
ive got mine in being powder coated at the moment should have it back next week ,once i have it back i could make you a copy if that helps
Posted: Sun Jun 07, 2020 12:24 am
by cleverusername
new to this wrote: Sat Jun 06, 2020 8:53 pm
Hi
Thanks for the offer, I don't want to put you out, it would probably be a lot of work, it is quite a complicated piece of metal work.
Posted: Sun Jun 07, 2020 3:17 pm
by xvivalve
Why wouldn't it? The brake master cylinders are identical across the range.
Be very careful when 'testing' a Sprint servo, if you depress the brake pedal without the cylinder fitted and charged with fluid you can shatter the diaphragm and destroy the servo.
The ring that secures the gaiter to the tunnel, or the tunnel itself?
Posted: Sun Jun 07, 2020 3:46 pm
by cleverusername
I tested it with it fully together, I am aware of the potential for the internals to shatter. I am pretty sure that is what happened to the 1500 one. I was worried it wouldn't fit because sprints seem to have remote reservoirs and there has to be a reason for that; I guessed it was clearance.
It is the metal ring I need, though I think I can probably fabricate something.
Posted: Mon Jun 08, 2020 12:19 pm
by xvivalve
The Sprint servo has slightly larger diameter which makes filling the integral clutch reservoir without spilling even harder, hence the remote reservoir, which was also fitted to some very late 1850s
I have spare gaiter rings if you struggle with the fabrication...
