Sprint shockers
Sprint shockers
Any recommendations for a full set of shocks for the Sprint.
Preferably as close to standard/original as possible - and good quality.
If someone has a full set of genuine ones hidden away, and willing to part with them, that would be dandy.
Club Membership No: 2017092
Re: Sprint shockers
I dont have a set, but OE fitment was blue Monroes.
I do have a single front and a single rear in NOS Unipart Red if thats any help.
Re: Sprint shockers
The fitment on mine was definitely Unipart, the ones I've just taken off (below), Can you PM me some photos Steve, I may be interested.
Re: Sprint shockers
I'll take some tomorrow!
Re: Sprint shockers
I have two Unipart single rear in red too...with slightly different heights to the spring platform!!
Re: Sprint shockers
I'll measure mine and post the height, underside of pan to bolt centre, then you can see if one of yours matches my one!
Re: Sprint shockers
Thanks, the part number on the fronts are GSA 402, I've not taken the backs off yet, but suspect they're GSA 404.
Re: Sprint shockers
Here are the pics Murdo
The front one is labelled GSA 335, whether this is a superceded part number I know not! The box says Sprint and 1850 in handwriting but it's pretty far gone with no actual part number on it. The rear had the remains of a box too but that got binned. I bought both at the Stoneliegh show in February. The rear has no discernible GSA part number and the distance from the bottom of the spring pan to the lower bolt hole centre is 145mm as near as I could measure it. The spring pan diameters are correct for Sprint on both shox. (as compared with my OE Monroes on my own Sprint)
HTH, Steve
HTH, Steve
Re: Sprint shockers
Thanks for that, so not the GSA 402 that came off the front, and no matching pair out of the 4 of them.
Ideally looking for a new pair, which are in good synthetic condition, purely for appearance reasons - if I did find a pair they could of course be repainted.
Re: Sprint shockers
By my reckoning, Steve and I have a matching pair of rears between us...
Re: Sprint shockers
I'll check the part number on the rears, I think they'll be GSA 404.
Re: Sprint shockers
Be interesting to know what the 335 is, and Alun's 336 - but who's the part number guru?
Re: Sprint shockers
Have found GSA 404 stamped on the 160 mm one and very very feint 336 on the 145 mm one.
I have a Unipart Shock Absorber catalogue....but all the references are the later 5 figure GSA 7**** part numbers
Re: Sprint shockers
Are they new old stock, or used shocks.
