It is currently Sat May 04, 2024 2:32 pm
Post new topic  Reply to topic  [ 24 posts ]  Go to page 1 2 Next
PostPosted: Fri Jul 10, 2020 8:05 pm
The garage, replacing the rack, I didn't remind them (again) 48 lb.ft - need I say more. Luckily only one wouldn't take 48 pounds, and I had a spare with manky corners.
So, will the 3/8 unf alloy wheel nuts take a coil well enough? I can't think of a reason why they wouldn't but I thought I'd ask.
PostPosted: Fri Jul 10, 2020 9:38 pm
theres not a lot of metal left on the side walls to take a heli coil, remember you have to drill them bigger to take the heli coil
PostPosted: Fri Jul 10, 2020 10:02 pm
I think the drill for a 3/8-24 unf helicoil is 25/64ths. Which is 3/64the smaller than the 7/16ths that the later nuts are threaded for - I assume it's the same blank as I understand the wheels are the same. So now I need to look at what the thread depth is. Think it's about 0.866/24 inches, if my geometry is still good. But what's that in 128ths?
PostPosted: Sat Jul 11, 2020 12:18 am
Well, 25/64ths is the drill size for 7/16ths UNF as well. And since the 24 tpi helicoil tap should cut shallower threads than the 20 tpi 7/16ths UNF tap, it should leave more meat in the walls. At least I think it will.
So I reckon I shall invest in a 3/8ths UNF coil kit.
PostPosted: Sat Jul 11, 2020 10:30 am
I have used helicoils for 3/8 UNF wheel nuts with success, both in the 1970s and more recently. Always because of uninformed mechanics.
The drill supplied with the kit is 9.9mm, just under 25/64.
I have gone Up to 60 lb-ft with no problem, just to be sure, then backed off again.
Peter
1978 Dolomite Sprint - Inca
PostPosted: Sat Jul 11, 2020 10:35 am
Peter
Thanks Peter,
That idea of going to a higher torque and backing off might offer a way to answer the related question I just posted, about what the limit on internal thread diameter might be.
But then the question would be what test value to use?
PostPosted: Sat Jul 11, 2020 11:04 am
Graham,
I don’t know what the minimum diameter will be. There isn’t much spare capacity in the nut to start off with.
I only know from testing on alloy generally that the pull-out strength of a helicoil is greater than the strength of the original alloy thread.
I only tested with 60 lb-ft to be confident that 50 lb-ft would be OK. I never had enough nuts to test to destruction!
It goes without saying that it is important to make sure the newly drilled hole is axial with the old one.
Peter.
PostPosted: Sat Jul 11, 2020 12:53 pm
Graham,
Peter.
Well, almost. I have been thinking about that. I suspect that if I take them to a shop with the capacity to do that to high accuracy, it'll exceed the cost of replacing with good second hand ones - there're some on eBay at £7.50 each for 3/8ths and £5.00 for 7/16ths.
I've only got a vice and a black and decker. But since I'm putting a 9.9mm (25/64ths) drill into a hole already 9.5mm in the case of the stripped one, I think it should be good enough to make a nut for the spares box. Slightly less confident if I decide to do the 8.6mm id ones.
As to the capacity in the nut walls: they are 17 mm od, and we're looking at 0.468" or 11.38 mm free outer diameter of the helicoil threads - which I think must be larger than the inserted diameter, but I'm not sure by how much (I'll measure the tap to be sure when I get it).
And that's compared to an outer thread diameter of more than 11.11 for the 7/16 unf thread - if anyone has a 7/16ths bottoming tap to measure, that would be interesting. That gives a wall thickness of about 2.95mm each side with the 7/16th. So coiling at 3/8 UNF give a wall thickness that must be no more than 0.14 mm less, or 6 thou off about 118 thou.
If someone can give me the 7/16ths UNF tap diameter, and I measure the 3/8 UNF coiling tap at anything like 12 thou bigger, I think I'll be fine with that.
PostPosted: Sat Jul 11, 2020 1:51 pm
Yes, I think if you use soft hands the old hole will guide you in OK.
If your nut is a write-off then nothing to lose.
My 7/16 UNF tap has a thread tip diameter of 11.15 mm.
Peter.
PostPosted: Sat Jul 11, 2020 1:57 pm
PS. My 3/8 UNF tap is 9.55mm 24tpi and the helicoil tap is 10.79mm 24tpi
Peter
PostPosted: Sat Jul 11, 2020 4:56 pm
My 3/8 UNF helicoil tap is 10.79mm 24tpi
Peter.
Forgive the edit please.
So the 3/8 UNF helicoil tap really is smaller than the 7/16ths UNF thread tap. By nearly 15 thou as well. That's good, as the helicoil set is on order. Only needs to do 2 nuts successfully to pay for itself.
PostPosted: Sat Jul 11, 2020 5:39 pm
That’s correct. Even with helicoil, there will still be more meat in it than a new 7/16 alloy nut.
And, even if your 3/8 nut is stripped smooth, it will still have to be drilled out slightly before tapping.
As you say, two nuts and you break even, and kits normally have 8 or 10 inserts in them 🙂
Peter
PostPosted: Wed Jul 15, 2020 1:16 pm
So, given the equipment and skills I have, the answer seems to be no.
I was able to drill out a hole that was 9.5, maybe 9.2 in places, to 9.9, though that wasn't easy into this hard an alloy, with the low torque curdless B&D I have. I hadn't any paraffin, so I used turps sub as a lube, which seemed fine. The drill went down true enough, but the tap didn't go in near as square as I'd want. Despite that would mean the nut would go on wonkey, I thought I'd just try to get a coil into that thread, which otherwise looked fine. But I just couldn't get one to start - never had this problem with helicoils before, though I've only done UNCs, not UNF, and that may make a difference. So after I'd bust the crossbars of two coils, I gave up.
I will look at getting one or two of the less totally buggered ones done professionally, but, even at £7.50 each for second hand ones, I can't see it being worthwhile. Maybe when there's none anywhere, it'll be worth it.
PostPosted: Wed Jul 15, 2020 3:23 pm
Every alloy thread I have done has been UNC, so I could imagine UNF being a challenge.
As for drilling for helicoils, attempting to do it with a hand drill is always pot luck. Really you need a pillar drill, to make sure you get it absolutely square.
Still you have lost nothing by giving it ago.
PostPosted: Wed Jul 15, 2020 3:54 pm
Have you tried http://www.grayston.biz/wheelnutmenu.htm
They do a wide range of wheel nuts.
There’s a guy on the Scimitar Forum that makes Stainless wheel nuts.
Think his name is a Bill and he’s based near Brighton.
I’ll try and find a His contact Details later.
212Hrs @31/12/2021
352 @ 28/11/2022
455Hrs @ 20/10/2023
480Hrs @ 14/03/2024
Working on a ratio of just 7Hrs a day not including driving to the Sprint.
That equals to 68 days that doesn’t include weekends.
Member TDC no 0471
Project 13B Sprint now back on.
Users browsing this forum: Amazon [Bot] and 3 guests
