Glove box light
Posted: Sun Jul 26, 2020 4:29 pm
by GrahamFountain
I came to this spare late number plate light while splitting a couple of bumpers for the end caps.
Anyway, as can be seen it's a push fit into the hole in the glovebox, which I understand there's not actually a part for. While this isn't the right part, it is at least Triumph Dolomite.
I haven't wired it up yet, but I can't see an issue to wire it off the unswitched 12v fuse, with the earth back through the glove box lid switch that is fitted.
Re: Glove box light
Posted: Sun Jul 26, 2020 4:40 pm
by geeksteve
I'd always assumed the hole in the top was for the retaining slidey bar thing on the left to go into - never actually checked though!
Re: Glove box light
Posted: Sun Jul 26, 2020 4:46 pm
by GrahamFountain
geeksteve wrote: ↑Sun Jul 26, 2020 4:40 pm
So it is. Never thought of that. Seen a thread somewhere about someone fitting an allegro or similar light there and just though this might fit.
So what's the switch supposed to operate then?
If it goes in parallel with the door switches, then the cabin light only comes on when the side lights are on, surely.
Re: Glove box light
Posted: Sun Jul 26, 2020 5:41 pm
by geeksteve
As far as I know the switch was just a parts-bin job to get the glovebox to pop open when you pressed the button.. I'm not sure it's connected to anything, certainly wasn't in mine. It'd be quite easy to cut a hole for a light and wire up the switch though, you've got power supplies behind the dash that'd be easy to join on to for the +12
Re: Glove box light
Posted: Sun Jul 26, 2020 10:36 pm
by Bumpa
geeksteve wrote: ↑Sun Jul 26, 2020 5:41 pm
That is certainly what the switch on my glovebox does. There's no sign of it ever having been connected to anything electrical.
Re: Glove box light
Posted: Mon Jul 27, 2020 6:28 am
by gmsclassics
Yes, I nearly used that hole until I realised. I fitted a T10 wedge for a small LED globe near top rear corner, best I could find to light up the glovebox without shining directly into one's eyes. Simple to wire up, from memory I used the cigarette lighter and an earth. Used the switch that is there. Works well, but in hindsight a small LED strip, stuck to the roof of the glovebox, pointing downwards might be better still. Geoff
Re: Glove box light
Posted: Mon Jul 27, 2020 8:04 am
by xvivalve
Whilst there is no light shown in the parts books, Ted discovered a light that fits the hole perfectly; from memory, I think it is the one fitted to the Morris Marina.
Re: Glove box light
Posted: Mon Jul 27, 2020 8:30 am
by GrahamFountain
xvivalve wrote: ↑Mon Jul 27, 2020 8:04 am
I think that might be what is said in the thread I vaguely remembered.
But if it fits that hole, where does the slotted bar go when the door is shut?
Re: Glove box light
Posted: Tue Jul 28, 2020 10:19 pm
by oily66
I’ve done it and bridged off the clocks lighting array through the switch that assists the door to open.
So it only comes on when the lights are switched on.
I used the light that clips to the cigar lighter as it can sit above the slot thus no modification to the bar needed.
Adjustment via the use of a video on the mobile phone confirms it goes off when closed.
Re: Glove box light
Posted: Tue Jul 28, 2020 11:03 pm
by Galileo
Thought that the 2000 had a glovebox light? It's been 35 years since I last looked so I could be easily mistaken or it was a retro fit. Only think it relevant due to it being the same style of dash in the MK2.
