No High beam
Posted: Sat Sep 12, 2020 8:50 am
by TZbaz
Been using the Sprint for a week now and everything is good apart from loosing high beam on the headlights . The flash works , dipped headlights work fine . Any thoughts as to where to start ? Is it likely to be the switch on the steering column ?
Thanks in advance
Chris.
Re: No High beam
Posted: Sat Sep 12, 2020 9:11 am
by tinweevil
TZbaz wrote: ↑Sat Sep 12, 2020 8:50 am
Yes.
If you've no relays fitted there's few alternative explanations.
If you have relays it is still worth checking the column switches first.
Re: No High beam
Posted: Sat Sep 12, 2020 5:18 pm
by TZbaz
Thanks for the reply, All sorted now. Cleaned up the contact on the brass contact and away we go !
Chris.
