Soda blasting
Soda blasting
Iv'e got a front panel which has some light surface rust, any idea how much to have it soda blasted ?
Re: Soda blasting
soda blasting is unlikely to take rust off an older panel.
Re: Soda blasting
If it's only light rust, rub it down by hand with some wet & dry, then prime.
Re: Soda blasting
I sort of have on the outside of the panel but it's the nook and crannies on the back i was hoping to get cleared up, maybe will give it a go with a light wire brush or a drill with a sanding flap
Re: Soda blasting
if you are selling it then personally I would just give it a light clean to get rid of the worse, don't paint it as most people want to see what they are buying and painting i makes it look like you are hiding rust so may put people, the buyer will likely want to get it cleaned and properly painted anyhow.
Re: Soda blasting
TrustNo1 wrote: ↑Fri Mar 19, 2021 11:25 pm if you are selling it then personally I would just give it a light clean to get rid of the worse, don't paint it as most people want to see what they are buying and painting i makes it look like you are hiding rust so may put people, the buyer will likely want to get it cleaned and properly painted anyhow.
