Steering rack u bolts.
Posted: Fri May 21, 2021 8:49 pm
by tonybsa
Where is the best place to get steering rack u -bolts. I have bought some from a well known Triumph supplier (not Rimmers), and they have sent me 8mm diameter instead of 7mm diameter, and they really do not want to go through the clamps.
Re: Steering rack u bolts.
Posted: Fri May 21, 2021 8:55 pm
by xvivalve
I have some used ones...
Posted: Mon May 24, 2021 10:19 pm
by tonybsa
Thanks. How much do you want for a pair including postage to County Durham?
Posted: Mon May 24, 2021 11:42 pm
by TrustNo1
tonybsa wrote: ↑Fri May 21, 2021 8:49 pm
That may explain the why i was struggling to fit a pair a few weeks ago, the did eventually fit.
Posted: Tue May 25, 2021 11:50 am
by Richard the old one
I have noted that on the later cars the U bolts are welded to the clamp but I have found that this then makes it difficult to get the U bolts and clamps out on a 1500cc so I prefer the separate U bolt type as you can then push the U bolts out and then get the clamp out.
Posted: Tue May 25, 2021 10:20 pm
by tonybsa
I agree with you Richard. On the Sprint the oil pump restricts access when trying to remove the u bolt, and clamp. I found the easiest way to refit is to bend the u bolt to about 15 degrees halfway up, place the u bolt into the clamp, about halfway, then you can get the clamp under the oil pump,and onto the rack mount, and the top of the u bolt between the block,and the pump. Then its just a matter of pushing the u bolt through the clamp, and into the subframe.
The 8 mm u bolts Jigsaw Triumph sold me will not only not slide through the clamp, but are too big to fit the u section of the clamp properly.
They are probably Ok for their solid rack mounts, but a poor fit at best, and at worst possibly dangerous if trying to fit to an original Triumph clamp.
