naskeet wrote: ↑Thu Feb 24, 2022 7:37 pm I also wonder whether the configurations (including the fastening-screw positions) of the two-piece moulded-plastic nacelles, are identical for the Triumph Dolomite 13/1500 with non-adjustable steering column and the Triumph Dolomite 1500/1850 HL & Sprint with adjustable steering column!?!
Clarification of this would be useful!
Carledo wrote: ↑Thu Feb 24, 2022 11:56 pmIn short, NO!
Besides fitting an adjustable column to the (plank dash) Carledo. much as you did, save I retained the plank dash, I also had need to fit an adjustable column to a (plank dash) 79 1500SE All went as the Carledo conversion, but, like the Carledo, the column nacelle wouldn't fit the adjustable column. The 3 screw positions were in alignment, but the 2 tags on the outer column through which the 2 longer screws pass were almost 1" out of position. I had to source a 2 part adjustable column nacelle.
Correct me if I have misunderstood, but are you now in effect saying the following?:
• The two-piece, moulded black-plastic nacelle from a 1970~76/77 Triumph Toledo fixed steering column, is incompatible with (i.e. will not fit) a “four-headlamp” Triumph Dolomite (i.e. Dolomite 1500HL, 1850, 1850HL or Sprint) adjustable steering column.
• The two-piece, moulded black-plastic nacelle from a “four-headlamp” Triumph Dolomite (i.e. Dolomite 1500HL, 1850, 1850HL or Sprint) adjustable steering column, is incompatible with (i.e. will not fit) a 1970~76/77 Triumph Toledo fixed steering column.
• The two-piece, moulded black-plastic nacelle from a 1976~80 Triumph Dolomite 1300, 1500 & 1500SE fixed steering column, is incompatible with (i.e. will not fit) a “four-headlamp” Triumph Dolomite (i.e. Dolomite 1500HL, 1850, 1850HL or Sprint) adjustable steering column.
• The two-piece, moulded black-plastic nacelle from a “four-headlamp” Triumph Dolomite (i.e. Dolomite 1500HL, 1850, 1850HL or Sprint) adjustable steering column, is incompatible with (i.e. will not fit) a 1976~80 Triumph Dolomite 1300, 1500 & 1500SE fixed steering column.
Would I also be correct in thinking, that you have previously said elsewhere, or at least inferred the following?:
• The two-piece, moulded black-plastic nacelle from a 1970~76/77 Triumph Toledo fixed steering column, is incompatible with (i.e. will not fit) a 1976~80 Triumph Dolomite 1300, 1500 & 1500SE fixed steering column.
• The two-piece, moulded black-plastic nacelle from a1976~80 Triumph Dolomite 1300, 1500 & 1500SE fixed steering column, is incompatible with (i.e. will not fit) a 1970~76/77 Triumph Toledo fixed steering column.
When I substituted the “four-headlamp”
Dolomite (i.e. Dolomite 1500HL, 1850, 1850HL or Sprint; I can’t recall which, but it had a “DOLOMITE” embossed steering-wheel centre pad) adjustable steering column into my
Toledo during the
winter of 1982/83, I retained the
Toledo’s original “flat-plank dashboard”, heater unit and parcel shelf. Substitution of a matching “four-headlamp” Dolomite parcel shelf would have been preferable, but I either could not find one in serviceable condition or didn’t realise at the time that they were different!
When
about 12~15 months later, I also substituted the “four-headlamp”
Dolomite (i.e. Dolomite 1850) sculptured dashboard with concave instrument panel into my
Toledo during the
spring of 1984, I still retained the
Toledo’s original heater unit and parcel shelf.
I might in the future, substitute a heater unit that I possess, originating from a “four-headlamp”
Dolomite (i.e. Dolomite 1500HL), but that is by no means certain! Alternatively, I might simply modify the original
Toledo heater unit which is still in the car, by retro-fitting custom-made hose-connection spigots to the rear and/or side-facing steel panels, which can supply hot/warm/cold air to supplementary circular vents (i.e. repurposed cold-air vents) positioned according to my preferences. This would provide greater scope for heating & ventilation, as well as more space for a relatively-wide custom console beneath the centre of the dashboard, for switches, radio / cassette-player, early-model Dolomite 1850 clock or other things.
Carledo wrote: ↑Thu Feb 24, 2022 11:56 pm As i've probably said before, the fitment of a different heater unit and differences in under screen fitting locations make it, in my opinion, too much work to fit a curved dash crash pad to a flat dash car.
As I have also said before, it is
unnecessary to change-out the
Toledo heater unit, when substituting the “four-headlamp”
Dolomite sculptured dashboard with concave instrument panel. The “four-headlamp”
Dolomite heater-control levers are compatible with the
Toledo heater unit.
There was very little extra work involved to install the
Dolomite sculptured dashboard in the
Toledo, apart from drilling three extra holes in the dashboard mounting flange below the windscreen, using a hand-drill. All of the installation work was undertaken in the CIT – Cranfield hall of residence car park, using just basic hand tools. Someday, I might get around to taking a few photographs to illustrate just how simple it was!
Carledo wrote: ↑Thu Feb 24, 2022 11:56 pm But the plank dash can be retained whilst fitting the adjustable column by the simple expedient of employing a pair of 1/2" spacers between the column bracket and the back of the crash pad and using 1/2" longer 1/4" unf setscrews at that joint. Everything else tallies up except the wiper switch wiring from the plank dash car which needs extending to reach the base of the steering column.
Unlike you, I bolted the
Dolomite adjustable steering-column mounting-bracket directly to the back of the
Toledo's dashboard, but used spacers (i.e. stacked washers) between the mounting-bracket and the
Toledo's vertical bulkhead separating the engine-compartment and the passenger-compartment.
I don’t recall needing to extend any wiring for the wiper & washer stalk-switch wiring, but given that it was nearly 40 years ago, it’s not surprising I don’t remember all of the details. I suspect that I might simply have unravelled some of the main wiring-loom binding-tape, to alter the position at which the wiring for the main lighting switch and wiper & washer switch emerged from the main wiring loom. Being a graduate applied physicist & engineer by background, who studied DC & AC electrical-circuit analysis amongst other things, and revelled in experimental research work, I’m not usually fazed by the prospect of fabricating or modifying wiring looms.
Carledo wrote: ↑Thu Feb 24, 2022 11:56 pm It's further my opinion that it's easier to cram more instrumentation into a flat dash than the somewhat restrictive curved design. The Carledo currently has 3 x 4" instruments, a) speedometer, b) tachometer and c) a three guage 4" clock from a Triumph 2000 MkII containing fuel, temp and voltage indicators. Plus a single 2" oil pressure guage, 4 individual warning lights for Ign, oil pressure, main beam and indicators and switches for brake line lock, rad fan over-ride, hazard warning light and HRW. The hazard and HRW switches are internally illuminated when switched on to save separate extra lights being needed. There is still room in the existing dash for at least one more 2" dial on the main panel to the right of the heater controls and the panel to the left of the heater controls is, as yet, untouched and blank.
I've achieved this much using the original plank dash panel which doesn't have the most practical space saving design, but I have plans for a bespoke flat panel to be made for me by a cabinet maker friend that will leave space for the 3 x 4" dials (slightly re-arranged for maximum visibility) and 4 further 2" dials, plus the 4 warning lights I consider necessary (might dispense with the oil light, I have a guage for that!) The 4 switches can be remoted to the left hand panel as none need to be easily accessed whilst on the move. All these instrument have been designed to be readable by me through a smaller 14" steering wheel. It may not work as well for anyone considerably taller or shorter than myself, but that's a really minor consideration as i'll probably be the only driver!
I reckon that by relocating the driver’s fresh-air outlet, my “four-headlamp” Dolomite sculptured dashboard with substitute concave instrument panel, will accommodate 3 x 4 inch instruments – (a) speedometer with ignition, oil-pressure & main-beam warning lights; (b) tachometer, and (c) three-gauge clock from a FWD Triumph 1300 incorporating fuel-level, coolant-temperature and amperes, plus 4 x 2 inch gauges – (d) inlet-manifold vacuum, (e) voltage, (f) oil-temperature, and (g) oil-pressure, plus 2 x 60 mm 8-segment customised warning-light clusters. I also envisage fitting two fog-light switches with integral tell-tale lamps, a hazard-warning-light switch with integral tell-tale lamp and a brake-circuit failure warning lamp. Having
nine gauge functions in total, plus
twenty warning lights and
three switches, is quite a reasonable compliment of equipment. There might even be space for at least another
eight individual warning lights if needed!
Would I be correct in thinking that
HRW might stand for Heated Rear Window? It never pays to make unsubstantiated assumptions, given that assumption is reckoned to be the mother of all disasters!
naskeet wrote: ↑Thu Feb 24, 2022 7:37 pm Although I might have once known the answer, I now wonder whether it might have been possible to retro-fit the
Dolomite steering-column-mounted, windscreen-wiper & washer switch, to the
Toledo’s original non-adjustable steering column and retain the original
Toledo's plastic nacelle; albeit with an extra slot cut in the nacelle to accommodate the extra switch-stalk!?!
It’s debatable how many
Toledo owners, would wish to contemplate substituting a complete
Dolomite steering column of either the fixed or adjustable variety, just to gain the advantage of having a windscreen wiper & washer stalk-switch and main lighting switch, mounted on the steering column. However, many more
Toledo owners might contemplate upgrading with just a windscreen wiper & washer stalk-switch, if it could be easily installed on the Toledo’s original fixed steering column and simply cut an extra slot or aperture in the
Toledo’s original two-piece, black-plastic nacelle to accommodate the switch stalk!?!
I’m no longer in a position to investigate this suggested option, so if any of you can usefully contribute any knowledge about this, then please do.
According to the Rimmer Brothers’ Triumph Dolomite Parts Catalogue, September 1998 edition, Page 32, there are two windscreen wiper & washer stalk-switches listed for the RHD Triumph
Dolomite models:
1850 (upto WF 26607) - part No.
216949
All models / 1850 (WF 26608 onward) - part No.
218502
I do not know when the WF 26607 > WF 26608 occurred, but I suspect that windscreen wiper & washer stalk-switches for the 1976~80 Triumph Dolomite 1300, 1500, 1500SE, 1500HL, 1850HL & Sprint are probably identical and interchangeable.
In what way the windscreen wiper & washer stalk-switches of part numbers
216949 and
218502 differ from one another, I have yet to learn!?!
I can find no corresponding listings on Page 40 or 41, for the FWD Triumph 1500 or RWD Triumph 1500TC, which I believe were similarly equipped, as indicated by the illustrations in Figures J:8 & J:10 on Page 107, Figure L:11 on Page 126, Figure L:15 on Page 129 and Figure M:21 on Page 145, of the following Autodata DIY workshop manual, so I wonder whether these cars required a windscreen wiper & washer stalk-switch of part number 216949!?!
John Millward, Triumph 1300/1500 from 1965 ~ 1973, Car Repair Manual, Autodata, 1980, ACRM277, ISBN 0-85666-049-3.
