Sprint oil pressure
Posted: Fri Jun 03, 2022 10:43 pm
Hello Dolomite owners, needing some advice regarding the Sprint engine.
I have owned various Triumphs including my TR5 for over 40 years, but they all have had a chassis and pushrods. I recently bought a TR7 with a Sprint engine to have a go hillclimbing and sprinting so I'm on a bit of a learning curve.
My first task was to helicoil nearly all the head tappings and adjust the tappets. It is fitted with a Kent fast road cam and on the rolling road produced 141 BHP which I thought quite respectable and far more than I expected.
On a recent track day, the oil pressure light started flickering under heavy braking and it then wouldn't idle as I nursed it back to the pits. It still turned over on the starter so wasn't seized and all the fluids remained in their proper places which was encouraging.
Fitting an oil pressure gauge was on my 'to do' list but hadn't made it to the top (TR7 does not have one). Back home I fitted a gauge and I was able to get her started and got maximum 20 psi. Not great.
Drained the oil - nothing untoward showing in the oil.
Having discovered the oil pump was on the outside of the block (what!) I ordered a new one to try along with the shorter relief valve spring as suggested by Robsport.
Put some new oil and oil filter in and with the short spring I get 40psi cold - not really enough.
So I tried the long spring. This gave me 70psi but I was immediately aware of a whirring noise in the block in the area of the jackshaft.
I think the engine will have to come out to check the bearings as a minimum but I'm intrigued by the noise from the side of the engine. What is the effect of high oil pressure on the jackshaft?
What should I be looking for as typical issues on the slant four?
Cheers,
Jerry
Cheers,
Jerry
