Little White Tolly thread: https://forum.triumphdolomite.co.uk/vie ... 19&t=15395
Later thread on the brown forum: https://autoshite.com/topic/17793-trium ... tr7-powah/
My current thread on the brown forum: https://autoshite.com/topic/50998-toledo-2000tc/
I'm going to be fitting a sprint gearbox and axle into my TR7 powered Toledo. It currently has an 1850 gearbox and axle. Given the larger rear drums, I'll need to reduce brake pressure at the rear to prevent them locking up.
Being a Toledo, I don't have a load sensing valve, and I have single circuit brakes. I thought about upgrading to dual circuit, but a few searches here suggest that might not be much of a real upgrade in terms of safety and performance and that the single circuit system is fine if kept in good condition. For what it's worth the current brakes are actually quite good.
Retrofitting an LSV seems like a pain, so I've bought a Vauxhall PRV as suggested by Careldo in various threads.
This is the one I've bought: https://www.ebay.co.uk/itm/261959741296
I've done brake lines before, but only replacing like for like I want to make sure I'm doing it right! When I'm fitting the valve, my plan is to cut and flare the existing pipe at a point inside the engine bay - I thought about doing just before the rear flexi but wanted to keep away from muck. I'll find and fit the correct unions onto the existing pipe - unless it looks like it needs replaced.
The thread dimensions on the valve are M10x1 female & M15x1 male, finding a M10 male fitment isn't an issue, but finding a M15 female for the other side is what I'm struggling with. Also, I'm concerned the existing pipe will be the wrong diameter for these unions. So the other option I'm thinking of is adding adaptors to the PRV to take it down to the correct size fitments for the car, and possibly connecting it directly onto the 4 way valve or an existing union, to reduce potential points of failure.
Alternatively, I think I have seen suggested fitting a smaller rear brake cylinder to the sprint axle to reduce braking pressure. I think there was some lively discussion about whether or not this would actually be effective, given it will still have larger shoes. But this is quite a tempting option, given the cylinders on the sprint axle are an unknown quantity, and the ones on my 1850 are known good units.
Could anybody that has taken either of these routes give me any pointers please?
