Page 1 of 2
Laminated replacement windscreen
Posted: Wed Nov 16, 2022 12:44 am
by Bunji
Had a truck (lorry) throw a rock at me and now have a shattered windscreen. I have glass cover on my insurance, however repairer says insurance will only cover installation of a laminated screen rather than original spare (which I have on hand).
I see Rimmers have laminated screens listed but it says 4-6 weeks ex their supplier, and I'm in nz so add another 4-6.
Are there other sources of laminated screens?
Re: Laminated replacement windscreen
Posted: Wed Nov 16, 2022 2:16 am
by gmsclassics
I did have a new laminated screen fitted in Auckland but that was over a decade ago. At the time I was told that was the last in stock in NZ. I'm not aware of any now, but haven't looked as haven't needed one.
Assume you tried all the major suppliers / installers direct? Could they get one, perhaps from Aussie? Best to leave sourcing a laminated one from overseas to your repairer as the packaging and freight cost of bringing a single screen in from the UK will be eye watering.
I've got a few old toughened screens in the barn, but I would try long and hard to find a laminated one before fitting a secondhand toughened screen.
Would the repairer do you a special deal to install your spare toughened one while they source a laminated one which insurer should pay all the costs for? Maybe worth asking?
Geoff
Posted: Wed Nov 16, 2022 5:53 am
by Philip Larmour
There are no laminated (or toughened) new screens available off the shelf in Australia.
An acquaintance recently had one custom made at a cost of A$1200 plus GST.
If you want to go this route send me a PM and i will get the details of the supplier for you.
Philip
Posted: Wed Nov 16, 2022 8:21 am
by SprintV8
You probably wouldn’t need a heated front screen but may be a option.
https://shop.retro-engineering.co.uk/la ... -125-p.asp
Posted: Wed Nov 16, 2022 11:47 am
by xvivalve
Carriage is likely to be your biggest problem.
Here in UK Kevin Robinson commissioned some copy windscreens and I can put you in touch with him, but glass per se is a prohibited material for all couriers I’ve used
Posted: Wed Nov 16, 2022 8:49 pm
Let your insurance co sort a replacement laminated one per their rules. In the meantime, take a pic (if you haven't already) and fit your spare one yourself it's not difficult, you are most unlikely to damage a toughened one fitting it and that'll keep you going till a spandy new laminated one arrives!
Aye..
Posted: Thu Nov 17, 2022 12:22 am
by sprint95m
xvivalve wrote: ↑Wed Nov 16, 2022 11:47 am
Use a pallet carrier?
A couple of months I used Caledonian Logistics to deliver 1000kg of glass from Glasgow.
Cost was £56+VAT.
Ian
Posted: Thu Nov 24, 2022 7:35 pm
by naskeet
Bunji wrote: ↑Wed Nov 16, 2022 12:44 am
Is there any reason why you cannot fit your own spare zone-toughened windscreen yourself, which will only require the assistance of one or two helpers, with protective gloves and a length of strong cord!?! Had your “original” zone-toughened windscreen not been shattered, it would potentially have remained perpetually in service.
Given that you had a zone-toughened windscreen rather than a laminated windscreen, were you carrying a universal emergency, roll-up plastic windscreen with reinforcement bars in your on-board emergency touring spares cache. I still have the one from the AA that we bought in 1975 for use with our 1973 VW 1600 Type 2 Westfalia Continental motor-caravan (still has the original factory-fitted zone-toughened front windscreen); especially when touring mainland Europe. A few months ago, I found that something similar is or at least was still available from Wootons Auto Accessories, in New Lynn, Aukland, New Zealand. A similar product is available from G & R Wills Wholesalers in Australia.
https://www.woottons.co.nz
An emergency windscreen available in New Zealand
AutoKing Emergency Windscreen available in Australia - Heavy Duty Lined Plastic Sheeting with Plastic Pull Tags – Size 2050 mm x 1012 mm (i.e. 81” x 40”)
https://www.grwills.com.au/product/emer ... indscreen/
The following 1970s vintage, classic product is currently listed (due to end on Saturday, 26th November 2022) on British E-bay, with a starting bid of £5•00, which is described in the listing as follows:
« Discovered in abandoned garage. Splendid 1970s period extra, from a time when windscreens weren't necessarily made of hardened glass and AutoGlass nowhere near conception. There's a very helpful list of cars for which it would be suitable, because it's a Deepscreen Model (rather than Standard model or Extra Deepscreen model) - see photo - ranging from the Austin 1100/1300 through the MGB GT to the Vauxhall Viva and VW Beetle (the original one). So I'd say it was about 1970-72. »
« It's never been used as far as I can see - nor even opened. Packaging, whilst fairly poor, is intact (not crumbling). »
« It would make a brilliant extra addition to the boot of your BMW 2002, any Ford Cortina or Capri, or Triumph 1500/Dolomite/2000/Stag (for example. Sadly I don't possess any of the vehicles described. »
Humphrey Thompson Enterprises – Compact Mk.II Emergency Windscreen
Raans Road, Amersham, Buckinghamshire
A member of the Rootes of Slough Group of Companies
https://www.ebay.co.uk/itm/234786499744 ... R4Cv0bOVYQ
And here's another from a different vendor, with a starting bid of £10•99
https://www.ebay.co.uk/itm/155271860815 ... R4Sv0bOVYQ
Posted: Thu Nov 24, 2022 7:59 pm
by SprintV8
Just a thought.
Watching one of those car shows might of been wheels dealers.
They couldn’t find a windscreen for a car.
They eventually got a car glass supplier to find a screen of the same curvature and managed to cut a screen out of this,
Maybe a option.
Posted: Thu Nov 24, 2022 8:12 pm
SprintV8 wrote: ↑Thu Nov 24, 2022 7:59 pm
Just a thought.
Maybe a option.
I saw that one! They cut a screen for a Saab 96 from one meant for some sort of Chevrolet! High art indeed!
Posted: Thu Nov 24, 2022 10:02 pm
by naskeet
Carledo wrote: ↑Thu Nov 24, 2022 8:12 pm
Just a thought.
Maybe a option.
I also remember that. The question is whether there is a similar windscreen guru in New Zealand.
Posted: Thu Nov 24, 2022 10:44 pm
naskeet wrote: ↑Thu Nov 24, 2022 10:02 pm
Just a thought.
Maybe a option.
Also the Dolomite has much more steeply curved ends where the Saab screen is relatively flat, it will be a lot harder to find a suitable donor as width is critical to the Toledo screen and modern cars are much wider.
I am….
Posted: Fri Nov 25, 2022 10:15 am
by sprint95m
Sorry, I cannot let that pass….
Are you seriously trying to suggest that New Zealanders are less or even non skilled?
It is a fact that people in remote locations are adept at finding solutions, they don’t have the luxury
of having everything at their fingertips
not that New Zealand is in any way remote.
Ian
Posted: Fri Nov 25, 2022 3:12 pm
by matt of the vivas
That's not even remotely what he's suggesting, no.
The "windscreen guru" was in the USA. Is there someone of similar skill here in the UK? Who knows. Its not any kind of slight on NZ.
Posted: Fri Nov 25, 2022 9:32 pm
by Bunji
Thanks all for your comments. I've tried a couple of specialist windscreen places here in NZ regarding getting a screen made, but they both suggested bringing in from the UK. Just waiting on insurance approval to get the order underway.
