Prior to this, My first call would be change the earth leads and live cable, I have lots of 4swg welding cable, which IMHO is about as good as you can get, Plans are eventually fit the battery in the boot, and get a bit of weight off the nose,
Having a nose about and following the live cable from the battery, there is a connector block saddled on it with quite a few brown wires going into it, thats a new one on me, before I cut it off and reattach all those wires together is there anything to look out for? from what was going to be a short mornings work, I think im looking at a couple of days now
What will I find inside this little block of wires if I open it up,
