The above has made me think.
The type of "anti fade" pads needs to be investigated. If they are still there after 11 years?
Mintex 1144 are excellent and have a coefficient of friction very similar to asbestos OEM pads. Even teh DS2500 pads I use on my spit have slightly less initial bite than asbestos pads in back to back testing, but once warm are excellent and amazingly long lasting.
I do wonder if the lack of servo is the big issue, and/or maybe a master cylinder with too big a bore making the brakes very hard. I used a remote servo on my toledo when the original one became intermittent (very scary) and that has worked well. As to m/cylinder bore, just try feel what the brakes are like without the engine running/no assistance, and you understand the problem. A non-servo car uses a much smaller bore master cylinder to improve the feel. changing from a 0.75 to 0.65 gives a 33% increase in braking force for the same leg effort. But care required as the pedal moves further, so with larger pistons in calipers you could run out of pedal.
She already has the TrackerJack conversion.
Golf GTI vented discs with Mintex anti-fade pads and shoes and Goodridge braided hoses all round.
https://forum.retro-rides.org/thread/11 ... op-bromley
Mine’s on 14” Stag wheels with 260mm vented Discs and Jaguar XJ 4pot calliper’s. (Chris Witor kit).
The article from Retro Rides also includes comment from the owner of another model from the same initial builder that this car apparently has NO SERVO on the brakes, something I find completely understandable as it'd be fighting for space against the Webers if one were fitted.
If there is no servo at all, that could well explain the lack of braking effort available. It will stop! But only with disproportionate effort from the driver.
If there is indeed no servo, and no room for one in the conventional position twixt master and bulkhead, i'd recommend a remote servo such as the one sold by the MGBHive. I've used these to good effect on a number of cars, both as fresh fit or replacement of the now hens teeth Girling Powerstop.
Reference in the article is also made to "anti fade pads" which may mean race pads. In any case, bin them and fit normal street pads, they are quite sufficient even for sustained track work, the vented discs themselves adequately take care of the fade problem.
Looking at the underbonnet pic in the RR pic would suggest there is indeed no conventional servo fitted.
