Hi All
Does anyone have a standard Sprint rear exhaust section? The bit that goes over the axle and the exit? Ideally in mild steel but stainless is ok.
I have a slightly butchered one down in Hove.
The twin pipes were shortened to fit a toledo body. And the joint at the front has been molested. The bits over the axle are all fine. It is mild steel.
If you want a pic, drop me a message with a number to whatsapp some over.
I don't want anything much for it, maybe a packet of chocolate hobnobs.
