AN fittings
AN fittings
Is there a way of connecting copper fuel line to AN fittings ?
thanks Dave
thanks Dave
Re: AN fittings
Re: AN fittings
Thanks but using that joint, it would be copper hard line then rubber hose to AN Fitting
is there a better way ? id like to go Copper straight to AN fitting
Thanks Dave
Re: AN fittings
ive never seen one that connect to hard pipe..only to hose.....unless you go to machine shop with drawings so they can make a one-off for you
Re: AN fittings
Dave,
Yes, you can get an adapter with an olive to 5/16" (and other sizes), then use a female AN fitting onto it.
https://www.ebay.co.uk/itm/383076228084 ... R6rsj9PkYQ
This company on E bay are very good to deal with.
Glen.
Glen.
Re: AN fittings
i stand corrected.....nice find glen
Re: AN fittings
GlenM wrote: ↑Mon Mar 27, 2023 11:34 pm Dave,
Glen.
Thanks Glen
Just ordered Dave
Re: AN fittings
as posted the compression one side and dash ,jic the other. -8 is a bit big and I would say -6 is plenty for 8mm pipe.
Re: AN fittings
Glen
Have you tired the AN quick release fuel fittings for fuel filter ?
Re: AN fittings
- Location: deepest Sussex any further and my feet are wet
Re: AN fittings
Somewhere in my box fittings I have another variant of Jic6 to metal hose, I think its a Russel fitting, its a rubber compression fitting !! obviously for low pressure applications, I think theres a reason its still in my box offittigs......... Im brave... not stupid.....Pics to follow if I can find the fitting.
Re: AN fittings
Dave,new to this wrote: ↑Thu Mar 30, 2023 4:23 pm Glen
No. I haven't got round to the fuel lines yet, I am still doing the turbo oil and coolant lines. I have got a pump and filter that I am going to mount under the boot floor, so I will take a look at those.
Glen.
Re: AN fittings
GlenM wrote: ↑Wed Apr 05, 2023 11:24 pmDave,new to this wrote: ↑Thu Mar 30, 2023 4:23 pm Glen
Glen.
Glen
I've got my fuel pump mounted inside the Dolomite tank and the filter under the boot floor, I've been using PTFE An fittings but you don't have as much flexibly on the fittings as the fast flow type, looks like i may have to alter a bit of mine![]()
