Gear box Leak
Posted: Mon Apr 03, 2023 10:30 am
by jlan1978
Morning All
I seem to have a small Gearbox leak that is coming from the very top of the Gearbox, looks like its from where the actual stick base if that makes sense.
Has anyone any experience of something similar? Is it a box out job to fix?
Re: Gear box Leak
Posted: Mon Apr 03, 2023 7:31 pm
by Richard the old one
What model of dolomite do you have?
Re: Gear box Leak
Posted: Mon Apr 03, 2023 9:20 pm
by jlan1978
1978 Sprint
Re: Gear box Leak
Posted: Tue Apr 04, 2023 8:29 pm
I will have to leave it to the Sprint owners to respond to you.
Re: Gear box Leak
Posted: Tue Apr 04, 2023 8:54 pm
by Mad Mart
Could be oil leaking passed the selector rod seals (106050).
Re: Gear box Leak
Posted: Tue Apr 04, 2023 9:09 pm
by jlan1978
Looks like its coming from under TKC 1000 on the drawing.
Would you know if it is them seals is it a box out job to replace?
Re: Gear box Leak
Posted: Tue Apr 04, 2023 10:21 pm
jlan1978 wrote: ↑Tue Apr 04, 2023 9:09 pm
There shouldn't be any oil there! TKC1000 is the part number for the whole housing but under the lever itself is open air. the selector rod seals Mart refers to area few inches further forward.
You can take the tunnel out, not a fun job as it also means removal of the parcel tray. Then you can remove the selector housing and replace the O rings with the box in situ.
Re: Gear box Leak
Posted: Wed Apr 05, 2023 9:40 am
by cliftyhanger
You need to get a proper look. Ideally clean it up with brake cleaner, drive it and look for where the leak is starting. It could be the top cover gasket, selector seals, I can't remember if the breather is up there too? That should be located and checked it is clear.
Re: Gear box Leak
Posted: Wed Apr 05, 2023 9:28 pm
by Robert 352
I suspect that it is those o-ring seals on the selector rods which are leaking.
Read the post
https://forum.triumphdolomite.co.uk/vie ... hp?t=31959
Find the right sized ½ inch vee seal and fit these instead of the o-rings and the problem disappears
See also this post
https://forum.triumphdolomite.co.uk/vie ... hp?t=29411
I remove the tunnel cover without removing the parcel shelf, and when that is done it is possible to remove the gearbox top cover without disturbing the gearbox.
Robert
