Rear brake cylinder
Posted: Mon Jul 24, 2023 7:11 pm
by Larry 1300
Hi I have a dolomite 1300,1980.
The brakes were poor when my wife drove her yesterday.
I had a look under the car today. There is brake fluid on the nearside back wheel. I am partially sighted.
I only saw one brake pipe going into the near side what I presume is the cylinder at the bottom. And what looked like a bleed nipple.
While on the offside there are 2 brake pipes.
There is still some fluid in the reservoir.
Any advice would be appreciated. I was going to order new brake cylinders but noted that there is a single one and a dual one for the 1300. Thanks
Laurence
Re: Rear brake cylinder
Posted: Mon Jul 24, 2023 7:34 pm
by ClassicFan
Brake pipe goes from the 'flexi' to the offside cylinder then across to the nearside which has the bleed nipple for both rear brakes so it's a single circuit system part GWC1110 - James Paddock have them for less than Rimmers
https://www.jamespaddock.co.uk/wheel-cy ... inegwc1110 but there are other suppliers
Posted: Mon Jul 24, 2023 10:25 pm
by Larry 1300
Hi thanks for your help
I have ordered it.
Posted: Tue Jul 25, 2023 12:15 am
ClassicFan wrote: ↑Mon Jul 24, 2023 7:34 pm
Don't like to rain on your parade, but ALL Dolomites have that stupid and potentially dangerous "to and through" axle brake pipe design. A 1980 car of any model should have dual circuit brakes, they were introduced on the Sprint on the series IV cars (VA30,000>) in late 78 and other models followed virtually immediately after. For check, dual circuit master has 2 pipes coming out and a single circuit car only one!
Posted: Tue Jul 25, 2023 8:36 am
by ClassicFan
Carledo wrote: ↑Tue Jul 25, 2023 12:15 am
Hmm I stand corrected, how that is true dual circuit though, where both rear brakes are connected is not. It's a 'Tandem' arrangement.
The alternate cylinder is part GWC1202 again available from James Paddock, Rimmers etc. Both were used on the Spitfire and other models so readily available.
Posted: Tue Jul 25, 2023 8:44 am
by xvivalve
You are correct, the Dolomite range was NEVER fitted with a dual circuit brake system, just a tandem master cylinder on later cars.
Posted: Tue Jul 25, 2023 8:48 am
by Larry 1300
Hi if I was to order a brake cylinder for the off side rear would I order the double one please?
Posted: Tue Jul 25, 2023 7:33 pm
xvivalve wrote: ↑Tue Jul 25, 2023 8:44 am
I'd argue that! True, the system used is not like the modern diagonal split which is universal today and has been since the early 80s, still it's a dual (dual meaning 2) circuit system, it just has a distinct front circuit and a distinct rear circuit, rather than a diagonal split. But there are still 2 completely separate circuits, each serving 2 of 4 wheels and each capable of functioning alone if the the other fails.
The only hydraulic bit shared is the reservoir.
Though, I will admit that, from experience, the braking effort generated by a dual circuit braked Dolomite if only the rear circuit is working, is marginal at best and the pedal only JUST above the carpet! The saving grace of this is, I would say more than 90% of failures involve rear wheel cylinders so the likeihood of you being left with ONLY the rear circuit is very low! And it's still better by far than a single circuit system where only a single point of failure can leave you completely devoid of brakes!
Posted: Tue Jul 25, 2023 7:36 pm
Larry 1300 wrote: ↑Tue Jul 25, 2023 8:48 am
The wheel cylinders are both the same, the threaded holes are both 3/8" UNF, so it doesn't matter if you have 2 pipes, or a pipe and a bleed screw.
Posted: Tue Jul 25, 2023 9:47 pm
by Larry 1300
Hi that's great thanks
