Page 1 of 2
I Changed the master and slave now the clutch is very heavy can you help
Posted: Mon Jul 31, 2023 4:54 pm
by Tricku2
Hello all,
My main issue is I changed the master and slave and the clutch went from fine to very stiff to press. Has anyone else had the same and or how to fix it, please?
Richard
https://www.ebay.co.uk/itm/182288482835
TRIUMPH SPITFIRE, GT6, HERALD, VITESSE CLUTCH MASTER CYLINDER GMC205
This is what was fitted.
My car is a kit type mainly Triumph Herald 13/60 chassis and running gear. The engine is a 1500 Dolomite
https://www.ebay.co.uk/itm/184323817149
CLUTCH SLAVE CYLINDER TRIUMPH HERALD & SPITFIRE 1965 ON GSY103
Re: ENGINE NUMBER IS IT A DOLOMITE ENGINE ENGINE NUMBER YC606224HE
Posted: Mon Jul 31, 2023 4:58 pm
by yorkshire_spam
YC is the prefix for a Dolomite 1500 engine
Posted: Mon Jul 31, 2023 6:42 pm
by xvivalve
If you join the Club we can supply you with not only the correct slave cylinder, but one that has been internally sleeved with stainless steel for longevity.
Posted: Mon Jul 31, 2023 8:03 pm
by Richard the old one
I recently sent a defective clutch slave cylindered away for refurbishment which included fitting it with a stainless steel sleeve because I did not see it listed on the clubs current spares list so has the club recently started to get them refurbished and if so what is the cost?
Posted: Mon Jul 31, 2023 8:12 pm
by xvivalve
I had three done Richard, as I only had three in the core pile at the time there was contention about the quality of the aftermarket ones. Two have sold and I have one left at £60. I didn't get any more done as when the manufacturer refused to modify the tooling of the aftermarket offering due to insufficient likely demand and instead terminated the product, David Manners undertook to have their stock sleeved and will operate an exchange system moving forwards. Not wishing to compete with them flavoured my decision, so they never made it onto the parts list, but I did promote the fact at the time that I had three on here and in my area report
Posted: Tue Aug 01, 2023 8:33 am
by yorkshire_spam
Tricku2 wrote: Mon Jul 31, 2023 4:54 pm ENGINE NUMBER YC606224HE
Hello all,
Can you help me I need to get the right slave cylinder and need to identify the engine.
I was told it was a Dolomite engine 1500 can anyone point me in the right direction to buy one, please?
Richard
Just to elaborate further... from the photo it looks like you have it installed in a kit car? If that's true then I think you need to confirm which flywheel/clutch arrangement you have. It's possible that the engine started life in a Dolomite, but changed over time. My Spitfire 1500 currently has a YC code engine installed, but the sump and flywheel were changed to Spitfire items to make it fit/work. Therefore it could have the Dolomite 1500 clutch slave rtc7215 OR the Spitfire version GSY103 (I think)
They both will FIT as IIRC the bell housing is the same, but they have different bore due to flywheel/master/clutch differences?
Posted: Tue Aug 01, 2023 9:44 am
I had consider getting a spitfire clutch slave cylinder and filing another notch on the other side but as stated I noted that the bore sizes were different when I looked at one at MossBros recently. That is how I came to get one refurbished as I had forgotten that xvivalve had advised that he had three refurbished.
Posted: Tue Aug 01, 2023 9:45 am
by Tricku2
Hi,
I got a new GSY103 fitted a new one twice, and the clutch is very hard to push down so I am trying to get hold of a Dolomite 1500cc slave as I think it is the issue. I sadly threw away the old one which I truly regret doing.
Richard
07974 357 911
Posted: Tue Aug 01, 2023 9:59 am
by ClassicFan
Tricku2 wrote: Tue Aug 01, 2023 9:45 am I got a new GSY103 fitted a new one twice, and the clutch is very hard to push down so I am trying to get hold of a Dolomite 1500cc slave as I think it is the issue. I sadly threw away the old one which I truly regret doing.
Slaves are the same bore though? - Sometimes people fit a larger master 3/4" instead of 5/8th" which makes the pedal harder. I have that setup and prefer it TBH
Posted: Tue Aug 01, 2023 10:44 am
by xvivalve
I think you’ll find suppliers supersede the Dolomite part number to GSY103.
This is the one the Club has left:
Posted: Tue Aug 01, 2023 2:58 pm
by Tricku2
Hi all,
Richard
Posted: Tue Aug 01, 2023 4:41 pm
by ClassicFan
Tricku2 wrote: Tue Aug 01, 2023 2:58 pm Hi all,
Richard
I refer to my previopus post, did you fit a 3/4" bore master instead of the standard 5/8th", that would make it heavier to press.....
Re: I Changed the master and slave now the clutch is very heavy can you help
Posted: Tue Aug 01, 2023 4:47 pm
by Tricku2
Posted: Tue Aug 01, 2023 11:26 pm
The 1500CC dolomite slave cylinder that I recently had refurbished had a 7/8 inch bore I suggest you check the bore size of the one you have fitted.
Posted: Wed Aug 02, 2023 8:10 pm
Richard the old one wrote: Tue Aug 01, 2023 9:44 am I had consider getting a spitfire clutch slave cylinder and filing another notch on the other side but as stated I noted that the bore sizes were different when I looked at one at MossBros recently. That is how I came to get one refurbished as I had forgotten that xvivalve had advised that he had three refurbished.
I need to correct this post I now believe the reason that I did not purchase the GSY103 was that it was an aftermarket item that had a different pipe size connections and that the bore size was the same.
