Front wheel bearings
Posted: Thu Nov 30, 2023 12:30 pm
by toryroger
Dolomite 1300. My annual "not-MOT" (=Safety Check) advised me to look at front left wheel bearings. I felt the amount of play at the tyres edge to be acceptable; but I have lifted out the outer and cleaned. Seems to me the bearing has rather a lot of movement - mostly up and down, but also some in and out. Can anyone advise me how much is ok please?
Thanks Roger
Re: Front wheel bearings
Posted: Thu Nov 30, 2023 3:21 pm
by cliftyhanger
Could be wear in the stub axle. That causes up/down, but not so much side to side.
The figure for play at the rim is in teh WSM somewhere, but a very small amount, as in the smallest amount I can get with teh castellated nut, is what I use. A friend (retired mechanic) does them up so he has no play. And before anybody says it causes a problem, he did approx 300k in his herald, now 150k on his spitfire, like that. With zero issues. But I amways go for a tiny smidge of play.
I do wonder if the setting up with play was to stop people overtightening them?
Posted: Wed Dec 06, 2023 1:15 am
by toryroger
Thanks. Got new bearings (Timken) from BearingKing. Remarkable - play barely perceptible.
Old ones came out quite easily, gentle drifting. But to replace -
has anyone tired the oven versus freezer system please?
Posted: Wed Dec 06, 2023 4:47 pm
toryroger wrote: Wed Dec 06, 2023 1:15 am Thanks. Got new bearings (Timken) from BearingKing. Remarkable - play barely perceptible.
In over 50 years of replacing this kind of taper bearing, i've never done anything BUT gentle tapping/drifting to replace the outer races. I've never cracked a race yet! So long as a modicum of care is used that the drift doesn't slip and scratch the bearing surface, you are good to go.
I once changed out a similar design of front wheel bearing on a 60s Austin Westminster at the side of the road on Salisbury plain on a Sunday evening, armed only with a hammer and a knife and fork (Jack and wheelbrace too, of course, being pedantic!)
Posted: Thu Dec 07, 2023 7:26 pm
by toryroger
No disrespect to Steve, or anyone else, of course....but my wife was making mincepies - I couldn't resist.....the hub went in the oven for 20 minutes (no idea how hot) and the new cones into the freezer for 10 minutes. They nearly dropped in; just tiny taps with a taper of wood, until they met the seat. The tone of the sound changed as they hit bottom.
Thanks all for advice.
