It is currently Mon May 13, 2024 3:01 pm
Post new topic  Reply to topic  [ 2 posts ]
PostPosted: Mon Dec 04, 2023 7:16 pm
I recently collected a job lot of parts from someone who used to own a 1300 FWD and need the bits shifting. I’ve been through and identified what bits he gave me and I came to the conclusion that although some bits are useful to me, the majority of them aren’t. So I’m just going to list everything that I can’t use in the hope that they’re useful to someone.
Steering Column
Front Quarterlight Rubber
Horn x2
Front Window Regulator
Rear Window Regulator
Fuel Pump
Steering Column Joints
Steering Rack Mounts and Bushes
Full Front Suspension Set inc. upper arm bolts
Sill Protector set
Petrol Cap
Radiator Cap
Windscreen Washer Nozzle x2
Blower Pipe Rubber Bend
Pair of Windscreen Wiper Arms
Battery Ground Clamp x2
Bonnet/Boot Catch
Clutch Line
Fan Blade
Red rear parcel shelf
FWD Front parcel shelf
Boot rear trim panel
FWD Dashboard vinyl
FWD set of black door cards
FWD Set if red door cards
FWD Brake Line Set
FWD Complete Steering Wheel
FWD CV Boot
FWD Dashboard Vinyl Pad
FWD Dashboard Wood Panel Set
FWD External Door Handles x8
FWD Headlight Switch x2
FWD Indicator Switch x3
FWD Inner Wing Repair Panel pair
FWD Pair of Ash Trays
FWD Pair of Front Door Card Inserts
FWD Pair of Side Lights
FWD Passenger Side Rear Chrome Edging
FWD Rubber Pedal Set
FWD Set of Internal Door Handles
FWD Steering Column Clamp
FWD Steering Column Cover
FWD Tail Light Rubber Gasket x3
FWD Tail Light Unit
FWD Throttle Cable
FWD Triumph Nose Badge
FWD Water Pump inc. thermostat housing
FWD/Early Front Seat Belts
FWD/Early Indicator Flasher Unit
FWD/Early Wing Mirror w/o Mirror
FWD Triumph Badge x2
FWD Set Window Winder Handles (Folding) x2
Gear Knob (ball)
Girling Shock Absorber
Light Switch
Rear View Mirror
Rotoflex Coupling Bolts
Set of 1300 Push Rods
Single Carb Intake Manifold
Strut Top
Thermostat
Triumph Badge Lettering
As for pricing, just offer what you think is fair.
If you want pictures of anything in particular, drop me a message, there’s too much stuff to put lots of pictures in this post.
PostPosted: Thu Jan 25, 2024 8:14 am
Good morning,
I have pm'd you in regards to some of this list, if parts are still available.
Thanks in advance,
1967 - 1300Fwd
Users browsing this forum: DotBot [Bot] and 0 guests
