Sprint heater hoses/connections.
Posted: Sun Mar 17, 2024 8:13 pm
by cliftyhanger
I am plumbing a sprint engine. Fitted a Golf rad and got that sorted, but now have to connect up the heater/manifold etc connections/hoses.
From memory (not with the car at the moment) there are
2 heater connections, one higher than the other
An outlet 1/2" from the manifold
A hose tail 5/8 from the water pump housing.
I know there is an H piece, presumably for the bypass. But are there any other connections? And what goes where? I like a heater that works, so want to get it right.
Re: Sprint heater hoses/connections.
Posted: Sun Mar 17, 2024 11:55 pm
From inlet manifold through H piece to upper pipe through bulkhead, then from lower bulkhead pipe thru H piece to water pump hosetail which, IIRC is aso 1/2". The H piece is omnidirectional, doesn't matter how you fit it.
This is also the direction of water flow through the heater.
HTH, Steve
Aye….
Posted: Mon Mar 18, 2024 3:02 am
by sprint95m
Just to add to Steve’s reply if I may,
you can improve the heater output by taking the heater supply
from the back of the cylinder head and also by using an 88 degree thermostat.
I have actually fitted a VW heater matrix into a Dolomite heater box
which is a bigger capacity and has larger stubs. Alas I don’t know how well this
actually works as I am yet to get my Sprint on the road.
Ian
Posted: Mon Mar 18, 2024 5:11 am
by cliftyhanger
Thank you both.
I can get on with that bit next (when I get time!)
Re: Aye….
Posted: Tue Mar 19, 2024 3:42 am
by SprintV8
sprint95m wrote: Mon Mar 18, 2024 3:02 am Just to add to Steve’s reply if I may,
Ian
Can you remember which VW model you got the heater matrix from.
Posted: Tue Mar 19, 2024 7:48 am
by RichardHyde
Here’s the original post Phil. I can’t see the images any more…
https://forum.triumphdolomite.co.uk/vie ... 9&start=30
