Shocks & Springs
wolf1000s
Shocks & Springs
#1 Post by wolf1000s »
Good evening all, can anyone advise me where to get a full set of shocks & Spring for the Dolly and do they come with all the relevant rubbers?
please advise
thanks in advance
cliftyhanger
Re: Shocks & Springs
#2 Post by cliftyhanger »
wolf1000s wrote: Sat Mar 30, 2024 7:39 pm Good evening all, can anyone advise me where to get a full set of shocks & Spring for the Dolly and do they come with all the relevant rubbers?
please advise
thanks in advance
The first question is whether you want anything uprated/lowered or whatever.
In terms of quality, ebay throws up OEM shocks (beware the ones with loose spring pans, they are often missing ot teh support rings are)
If you want adjustable, GAZ seem to be ok, and also available in height adjustable.
As to springs, it seems to be the wild west out there, if you want std springs I would reuse your own.
As to rubbers, new shocks should come with teh eye rubber and the top mounts rubbers. They will NOT come with the top pans or the large rubber washer that the spring sits on.
#3 Post by Mad Mart »
I have a brand new set of shocks & springs that I bought from Rimmer Bros. for one of my Sprint projects, 8-10 years ago. Never used them as the customer wanted to upgrade to Spax.
wolf1000s
#4 Post by wolf1000s »
cliftyhanger wrote: Sun Mar 31, 2024 10:17 am
please advise
thanks in advance
i was thinking of keeping it standard not going to spend too much on this one it wont be worth it in the long run, just want to make it a better drive, done top ball joints and tightened up wheel bearings, will need to do the Carbs as running rich and i believe its the wax jet type so they need a overhall, ill see how i go, its running and driving so done want it stuck in the garage
wolf1000s
#5 Post by wolf1000s »
Mad Mart wrote: Sun Mar 31, 2024 10:34 am I have a brand new set of shocks & springs that I bought from Rimmer Bros. for one of my Sprint projects, 8-10 years ago. Never used them as the customer wanted to upgrade to Spax.
Hi
is this set of shocks & Springs full front & rear? what are you looking for? i have a limited budget i have seen how expensive Rimmer is, please advise
kind regards
Wayne
#6 Post by Mad Mart »
PMd.
