Think I’ve broken my servo
Re: Think I’ve broken my servo
#16 Post by xvivalve »
shaunroche wrote: Wed May 08, 2024 9:05 pm
xvivalve wrote: Wed May 08, 2024 1:54 pm
shaunroche wrote: Wed May 08, 2024 1:05 pm There's a lad at work here who's mad about 3d printing....if someone can supply a fag packet sketch I could ask him about getting some made perhaps.
It's more complex a casting than a fag packet sketch.....!
Which bit are we talking about on here?....
I've never seen inside a servo before!
SprintV8
#17 Post by SprintV8 »
What does the Bakerlite look like.
You say you tried Alloy.
Is Steel a option.
Be much more hard wearing that Alloy.
I can asked my Engineer/ Machinist's if that’s helps. I
212Hrs @31/12/2021
352 @ 28/11/2022
455Hrs @ 20/10/2023
565Hrs @ 07/12/2024
Member TDC no 0471
#18 Post by xvivalve »
Bakelite is the material pre-war light switches and door handles used to be made of, often mottled brown in colour; a bi-product of the coal industry, I believe.
One of the Ford owners commissioned a piston to be machined from steel billet; it cost him £500 apparently, but when he gave it to the reconditioners to put into his servo they found it was too heavy for the limited manifold depression to move it back and forward.
The issue with the light alloy version is a 3 mm slot needs to be milled into the centre shaft, but the resulting thin wall it creates keeps bursting before the slot is completed. They're looking at whether reinforcing the wall would be detrimental to other operation of the servo...and I've suggested they might move the split between the two cast parts to the slot location so that when they then TiG together the slot is created by a machining in one part prior to mating them together...
Work in progress...
SprintV8
#19 Post by SprintV8 »
Do you have any pictures of the bakerlite component.
Could it be made in two pieces.
Steel insert with a the outer in alloy.
Would Titanium be a viable option if a steel insert was possible.
Light but expensive
What grade of alloy are they trying.
212Hrs @31/12/2021
352 @ 28/11/2022
455Hrs @ 20/10/2023
565Hrs @ 07/12/2024
Member TDC no 0471
new to this
#20 Post by new to this »
xvivalve wrote: Fri May 10, 2024 9:53 pm
Its an odd shape i can see why your have trouble making it, another option could behave it sand cast make the wall thicker cut the 3mm slot then remachine wall back down if you need to, as you say Brass or ally could be used
if you need help there a sand cast place near me
#21 Post by xvivalve »
SprintV8 wrote: Sat May 11, 2024 9:14 am Do you have any pictures of the bakerlite component.
Light but expensive
It seemingly has to be made in two pieces, hence the TiG weld prior to final machining. I've no idea what grade they're using, just reporting what I'm told at each update. I don't have a picture to hand. Mart took one away that had been cut in half and made a CAD model of it...
new to this wrote: Sat May 11, 2024 11:24 am
It's in the hands of the reconditioners who I use who have external expert contacts they use regularly for casting, machining, 3d printing etc. I'm not involved beyond the expression of interest I've made that the Club would provide them with more custom beyond the Ford models if they're successful...
#22 Post by Mad Mart »
Here you go...
GlenM
#23 Post by GlenM »
I am not sure about this particular component but some Bakelite can contain asbestos.
RichardHyde
#24 Post by RichardHyde »
Old servo rattles when I shake it. Guess that’s fairly conclusive that the Bakelite piston has broken !!
#25 Post by xvivalve »
Unfortunately, yes
dursley92
#26 Post by dursley92 »
I am intrigued by what function the Bakelite disc performs inside the servo.
Its not a strong enough material to be subjected to full brake pressure so looking at the pictures above it may be some kind of support/former for the rubber diaphragm?
Russ Cooper
Dursley
UK
