Fuel pump fitment
woolley11
Fuel pump fitment
#1 Post by woolley11 »
Anyone had trouble fitting a QH fuel pump on a Sprint?
Seems to be a tricky blighter - played around for 10 mins but left it as getting annoyed.
Is there supposed to be a spacer at all ?
Let me know
VW Mk1 Golf GTi Campaign - Alpine White (A reg)
Dolomite Sprint - Magenta (M reg)
Vauxhall Omega MV6 - Champagne (S reg)
BMW Alpina B10 3.3 Touring (51 reg)
Shaun
Re: Fuel pump fitment
#2 Post by Shaun »
What is the length of the arm?
woolley11
#3 Post by woolley11 »
It measures 60mm from end of body to tip of lever (max length)
Part number is QFP33
#4 Post by xvivalve »
Yes, that model requires a spacer; you'll find two gaskets in the box, one for each side of the spacer (but no spacer!)
A non spacer armed pump is just shy of 50 mm.
woolley11
#5 Post by woolley11 »
Thanks - that answers the question.
Seen some on eBay - mainly for Mini but are these the same?
Ridiculous they don’t supply spacer
#6 Post by xvivalve »
No idea
https://rimmerbros.com/Item--i-UKC8523
but try Fitchett's and Abingdon first...
#7 Post by MIG Wielder »
When I replaced my fuel pump some years ago I did a drawing of it and the Long Arm replacement ( Attatched )
If you print the graph paper out full size ( the squares are 1cm x 1cm ) and place the edge of the fuel pump on the left hand side you can check whether it is an early or a late version. Fig 1 is the early one. Fig 2 is the late one and Fig 3 is the late one fitted with the UKC 8523 plastic spacer.
HTH,
slant4 fuel pump shrink.jpg (53.72 KiB) Viewed 4743 times
woolley11
#8 Post by woolley11 »
Thanks for that - seems spacer is order of the day
dursley92
#9 Post by dursley92 »
woolley11 wrote: Sat May 11, 2024 12:23 pm Thanks - that answers the question.
I think they expect you to re-use your existing spacer.
Bit tricky if you are replacing a short armed one without the spacer!
Russ Cooper
Dursley
UK
dollyman
TDC Cheshire Area Organiser
#10 Post by dollyman »
I just used two mini ones, only because i had them and they work fine. 8)
