Triumph Dolomite Boot Seal
Posted: Fri Dec 27, 2024 3:54 pm
by David Embery
Hi,
Pictures below show the replacement boot seal I have received for my 1972 Triumph Dolomite 1850.
Does anyone have any views on whether this looks like the correct seal? Just looking at it next to the car, it looks rather too fat and therefore unlikely to fit. Is there another version of the seal I should be getting instead?
Would very much appreciate hearing member’s views and if there are any particular points/tips I should keep in mind in order to successfully fit?
David
Re: Triumph Dolomite Boot Seal
Posted: Fri Dec 27, 2024 5:46 pm
by xvivalve
The boot seals you can buy today are indeed too fat and may prevent the boot lid from shutting or if it does not sitting flush. NOS if you are lucky, or find a good used one....
Posted: Fri Dec 27, 2024 7:36 pm
by tangocharlie1
Where did you get it from ?
As already stated good nos is your best bet, but i have known people use COH Baines with positive results it may prove a decent alternative.
https://coh-baines.co.uk/search?q=boot+ ... h+dolomite
Posted: Fri Dec 27, 2024 7:54 pm
by David Embery
Thanks Alun & Charlie.
:D
I’ll give the alternative a go as suggested by Charlie.
Posted: Sat Dec 28, 2024 11:29 am
by xvivalve
Before you buy one from Baines, ask if they supply the place you bought the first one from...they probably do!
Posted: Sat Dec 28, 2024 3:33 pm
by David Embery
Cheers Alun. I’ve sent an email to lhdclassicparts on eBay. I’ll keep you posted on progress. :D
Posted: Sun Jan 05, 2025 7:31 pm
by 10yearsafter
I have just had one from Chris Wittor fits perfectly. Rimmers were not good.
Bob
Posted: Sun Jan 05, 2025 9:40 pm
by David Embery
Cheers Bob. I’ll take a look at Chris Whitor’s web-site. :D
