Sorry if this is a daft question but I would really value member opinions on which type of coolant/anti-freeze I should use with my recently re-built Dolomite 1850 engine?
I have always been under the impression blue coolant/anti-freeze is for older engines that are principally cast iron. I.e. The straight six in my TR6. The red/pink variety of coolant for more modern engines that are basically all aluminium. As my 1850 engine is a cast iron block with an Aluminium head, I’m a bit unsure as to the best way forward.
The pink stuff reacts unfavourably with brass, like some radiators and always the heater rad.
David Embery wrote: ↑Fri Apr 04, 2025 7:59 am
My new Rad is an aluminium upgrade Steve.
Does that mean Red/Pink is now best or is it still the blue stuff?
David
David, I tend to use this from GSF, in both my sprint (ally Golf rad fitted) and my spitfire (ford engine, ally golf rad, done nearly 50k in 10 years)
I use a 50% mix, no need to skimp! Stays clean, change every 2 years. Job done. https://www.gsfcarparts.com/products/bl ... kBH_nh9sik
Even if your main rad is alloy, the heater rad is still brass, so pink is still a no-go.
In my 1500TC I have ran Prestone universal coolant since 2015 with no issues (Original rad and water pump, I think as I have not replaced it). Its easy to get and since I use it in my 2000 BMW without issues it makes it cheap.
Although I only do about 2000 miles a year and change it every 4 years with a flush (always seem a shame as after the first change it looked perfect and tested well, but I like to tinker!).
