Flywheel
Tallpaul
Flywheel
#1 Post by Tallpaul »
Hi anyone got tips for holding flywheel. I have to remove mine to get to rear crank seal. Ta
RichardHyde
Re: Flywheel
#2 Post by RichardHyde »
Take the clutch off and put one of the clutch bolts back into the flywheel.
Put a long bolt in block where one of the gearbox bolts is located.
Put a spanner so one end is on the clutch bolt and the other is on the gearbox bolts to stop it turning…
RichardHyde
Re: Flywheel
#3 Post by RichardHyde »
dursley92
Re: Flywheel
#4 Post by dursley92 »
I just used a bent piece of scrap metal and a bolt
Russ Cooper
Dursley
UK
Re: Flywheel
#5 Post by Mad Mart »
I printed one of these a few years ago...
Tallpaul
Re: Flywheel
#6 Post by Tallpaul »
Thanks for the replies. Very helpful
