Hi All,
Just wondering if anybody has had the same problem as myself. I am having trouble selecting reverse with and without the engine running. All the forward gears are no problem at all. After a run when the parts are hot it is almost impossible to select reverse.
Clutch is fine and oil level is fine.
Any suggestions?
Cheers Phil
Difficult to get reverse
Re: Difficult to get reverse
Possible fracture of the operating arm lever
Possible broken wedgelock bolt
Possible embolism in the clutch master to slave pipe.
