Wheel studs
Posted: Thu May 08, 2025 6:23 pm
by Chumley
Hi just thought I’d post this might be of some use to someone in the future. I needed to change rear studs so thought I would try without removing hubs because either way the cover needs to come off the back of hub. I tapped carefully has I could around hub and tapped back one section fully to see if I had room to change studs.
Image b
Managed to change quite easily with plenty of room but drawing them through was not easy but managed with washers and nuts to do it vey carefully
I tapped backplate back round but just need to find a way to fix them or don’t know whether to remove them altogether
Re: Wheel studs
Posted: Fri May 09, 2025 8:05 am
by bazyerma
Hi Chumley
When I fitted my MG studs, I did away with the back plate and put Loctite on the splines and I have had no issues.
Regards
Barry
Re: Wheel studs
Posted: Fri May 09, 2025 3:38 pm
by Holiday97
When I replaced my rear studs I removed the hub and worked on my bench, which worked out much better.
Re: Wheel studs
Posted: Fri May 09, 2025 7:37 pm
by Chumley
bazyerma wrote: Fri May 09, 2025 8:05 am Hi Chumley
Regards
Barry
Thanks for the reply Barry that’s good to know
Re: Wheel studs
Posted: Fri May 09, 2025 7:40 pm
by Chumley
Holiday97 wrote: Fri May 09, 2025 3:38 pm When I replaced my rear studs I removed the hub and worked on my bench, which worked out much better.
Thanks I thought about that but read that it can be a right pain removing the hub without the correct puller did you replace the backplate
Re: Wheel studs
Posted: Mon May 12, 2025 11:27 am
by Holiday97
I brought the correct pulleryes it was very tight but it came off with a bang. Using the puller I did not have to disturb the brakes or back plate. Now I have a puller for any further work
