Page 1 of 3
Alternative to obsolete pivot bolt?
Posted: Sat Dec 08, 2007 4:53 pm
by MarkVeryard
Hi Folks,
Have been stripping my front suspension today so that I can re-bush it - but the damn pivot bolt that connects the lower wishbone to the mounting bracket was stuck fast so I had to cut it off.
Trouble is that Rimmers list this part as 'no longer available' (part 216901) - does anyone know there I can get one, or whether there is a suitable alternative? (or is there something special about this bolt?)
My best guess so far: the front shock absorber lower mounting bolts seem similar (BH606201) but would need the threaded length extending.
Any advice from the gurus?
Cheers,
Mark.
Posted: Sat Dec 08, 2007 4:58 pm
by 2F45T4U
Take the other side one out and go to Swansea Fasteners, they do Imperial stuff too
Posted: Sat Dec 08, 2007 7:04 pm
by xvivalve
I have some s/h ones...
Posted: Sun Dec 09, 2007 10:33 am
by DavePoth
You mean that really long one? I soaked it in wd 40 for a week (more WD every evening) then used a 2' breaker bar on one end, and the other end a large ratchet wedged under the subframe. I think I only had to jump on it a few times before it came loose...
I'd quite like to renew mine if a supplier does come up, I can't think it would have liked that sort of abuse too much.
Posted: Sun Dec 09, 2007 11:19 am
by Carl
I bought some brand new ones from Fitchetts in the summer.
Posted: Sun Dec 09, 2007 11:36 am
by george
quick trip over to 'swansea' fasteners enterprise zone by ashmoles fiat alfa dealers
Posted: Sun Dec 09, 2007 3:10 pm
by Mad Mart
The bolt is an ordinary bolt afaik but with a slightly thinner head. Pt. No. 216901
Posted: Sun Dec 09, 2007 4:14 pm
by xvivalve
Its not on that diagram Mart; its the long one which passes through the upper wishbones at extension of the sbframe...
Posted: Sun Dec 09, 2007 4:56 pm
by Dollyboy
mark said lower wishbone bolt, however the bottom arms arent wishbones though.
mart can you whack up diagram for the top part of the suspension and mark can tell us the number he means
:wink:
Posted: Sun Dec 09, 2007 5:38 pm
by Howiesprint
He did also say that it looks similar to the bottom front shock bolt....... so I think the one you have stated Mart is the one.
Easy to locate....
Posted: Sun Dec 09, 2007 6:28 pm
by sprint95m
The part number Mark quoted is for the track control arm bolt. These are a standard UNF size and are available from motor factors or agricultural machinery suppliers.
The shoulder length (unthreaded bit) is important in this application - do not use a machine screw (threaded up to the head) even if it is the same overall length.
unf bolt
Posted: Sun Dec 09, 2007 6:57 pm
by NO41SPRINT
Hi ,let me know the size and I am sure we will have one in stock.Is it a nut and bolt ? if so ,why cant a metric equivilant do?
cheers
Re: unf bolt
Posted: Sun Dec 09, 2007 7:06 pm
by sprint95m
NO41SPRINT wrote:Hi ,let me know the size and I am sure we will have one in stock.Is it a nut and bolt ? if so ,why cant a metric equivilant do?
cheers
A metric size is not suitable because the diameter will be different, eg for 3/8"UNF applications M8 is too small and M10 too big.
Posted: Sun Dec 09, 2007 7:44 pm
by Autonet7
Call these guys. I have used them to replace several bolts on my car including the exhaust manifold to head bolts. They are pretty cheap too compared to Rimmers. http://www.margnor.co.uk/=contact.htm
If they won't post or take cards, let me know, I'll pop in and get them for you and post them on.
metric
Posted: Sun Dec 09, 2007 7:49 pm
by NO41SPRINT
Hi ,know that in some cases that metric and imperial arent the same diameter size,but in some they very close.
chances of finding an imperial bolt in a long length is very rare,unc is better than unf though.
a fully threaded bolt is called a set screw.
I changed all my 5/16unf to m8 stainless steel on the steering joints.
anyway ,let me know
