Pistons
Pistons
#1 Post by xvivalve »
I finally found the set of new Sprint pistons I had secreted away last evening. They are Mahle. If the piston in the quicksprint is damaged then I would propose to replace the lot...any substantiated opinions on the use of these for that purpose?
Carl
Re: Pistons
#2 Post by Carl »
Seems generally accepted that they are 'desirable'. I have a set ready for that 'new' engine one day ....
Re: Pistons
#3 Post by Mad Mart »
I have a block with Mahle pistons in ready for my Track Sprint when the current engine decides to give up the ghost.
SPRINTPARTS
Re: Pistons
#4 Post by SPRINTPARTS »
I would not hestiate in using the Mahle pistons in a race type motor. Over the years we have used Mahle and Hepolite (and forged pistons when we had some money to burn). I believe that the Mahle pisons are of good quality and strength for a cast piston and are lighter than Hepolite, go for it.
Hans ten Broeke
Re: Pistons
#5 Post by Hans ten Broeke »
If some one is serious interested, I'v have about 6 new sets Mahle pistons
Bdw is that a bad picture of the red engine or do I see marks in the liners??
Hans
Re: Pistons
#6 Post by Mad Mart »
Hans wrote:Bdw is that a bad picture of the red engine or do I see marks in the liners??
The block had been sat around for about 5-6 years & wasn't covered so lots of debris got into the cylinders. I will strip & rebuild it before I use it.
Hans ten Broeke
Re: Pistons
#7 Post by Hans ten Broeke »
Carl, can't get the answer working trough this list, don't know why, so contact me direct on my private adres hans@racet.nl with your own mail adres so I can respond.
Cheers, Hans
Carl
Re: Pistons
#8 Post by Carl »
Message sent Hans :wink:
