Grease
Posted: Fri Mar 21, 2008 6:05 pm
Just been stripping down the reconditioned engine I bought a few months ago. Thought I'd check the mains & big end bearings to see what size they are (they are standard). When I took the bearing caps off I found the bearings & crank covered in a dark grey grease. Should I remove this grease or will the oil wash it through.
