Sprint Alloys Tyre Sizes
I have just bought a set of sprint alloys for my toledo. What i have noticed is the two of the tyres are 185/70 R13 and the other two are 165 R 13. Which ones are the correct size for the dolomite/toledo.
Alan
Alan
the 185 or 165 is the width , more width = more grip but you may have rubbing issues in the inner arches the 70 means the tyre wall height is 70% of the width.
so a 185/70 will be taller then a 165/70 will will give diiferent speedo readings by 2.25%.
not answered your question as it?
off topic,are you going sunday?
Also a 195/50X15 on a 7J rim clear's the rear arch OK
212Hrs @31/12/2021
352 @ 28/11/2022
455Hrs @ 20/10/2023
565Hrs @ 07/12/2024
Member TDC no 0471
212Hrs @31/12/2021
352 @ 28/11/2022
455Hrs @ 20/10/2023
565Hrs @ 07/12/2024
Member TDC no 0471
On any tolly/dolly with less than perfect bushes and springs 185 will rub on corners, potholes, at the bottom of dips etc. Put weight in the back or boot and it gets worse.
Tinweevil
Tinweevil
I'm running 185/70's and my car is very low. Rear arches have been "rolled", and I never get any contact on the rear.
Fronts only rub when I've got a fat bloke for a passenger, when cornering on full lock. (i.e. turning round in a side street)
Never get any rubbing when it's just me in the car, under normal and even hard driving.
I can't do potholes, speedramps etc anyway!
Adam
Adam
How much for said item as poor Adam is a Student and you'll never see the colour of his money.of course i do have a new boxed rack
212Hrs @31/12/2021
352 @ 28/11/2022
455Hrs @ 20/10/2023
565Hrs @ 07/12/2024
Member TDC no 0471
212Hrs @31/12/2021
352 @ 28/11/2022
455Hrs @ 20/10/2023
565Hrs @ 07/12/2024
Member TDC no 0471
