How do I get the window winder off?
Whilst winding the window down today, the black knob came off the end in my hand... oo er missus... Anyway it looks like the metal fastening on the back of the knob has broken so I'm on the look out for a replacement. But how do I get the window winder off? I cant see any screws or anything...
- AndyThomas
Winder
If you push the black plastic surround back you will see a metal pin which you can push out. The hard part is getting it back in again whilst pushing the plastic surround back.
Andy
Andy
Push the black plastic bezel back and look at the metal "shaft" of the winder handle (you'll have to jam a screwdriver between them to stop them closing up) then rotate the handle slowly you will note that there is four holes passing through it, one of these 4 has a metal peg in it that you can push throught with the end of a nail etc.
Once the peg is removed you can pull the whole metal winder away.
Be careful that you don't loose the metal peg as it will just drop out as you push it through.
To refit you'll need to have a pair of long nosed pliers to put the peg back in the hole.
Or use a R shape clip.
You can get them from most good DIY stores and some of the crap one's too.
212Hrs @31/12/2021
352 @ 28/11/2022
455Hrs @ 20/10/2023
565Hrs @ 07/12/2024
Member TDC no 0471
212Hrs @31/12/2021
352 @ 28/11/2022
455Hrs @ 20/10/2023
565Hrs @ 07/12/2024
Member TDC no 0471
Window winder problems
The knob coming off is a common problem but once you have taken the handle off you can normally rivet it back on. This stops the knob turning but I have not found that to be a problem and once riveted I have not had any further problems.
