Input shaft tool
Posted: Mon Dec 11, 2006 12:12 am
by 1300dolly
On the way home tonight my clutch was slipping on the fwd :cry: . Am i correct in thinking that the input shaft needs to come out and this requires a special tool?
I remember someone mentioning a 3/8 thread? bolt , mole grips and hammer. how does this work?
or did i imagine that bit?
tool
Posted: Mon Dec 11, 2006 11:41 am
by slant4
Think there is a tool, similar to a slide hamer? You could pull it with a pair of mles, but I suspect its to loosly clamp arond the bolt and the hammer to make it pivot against the transfer gear casing?
Posted: Mon Dec 11, 2006 12:58 pm
by 1300mash
The proper slide hammer screws into the end of the input shaft where the little nylon bolt is I believe. Steve W probably has one (or knows where there is one) and I think David Paynter who bought the service tools off eBay this year too.
Posted: Mon Dec 11, 2006 4:10 pm
by 1300dolly
cheers i will call steve later as i need to order a clutch.
