Diary of Scott, aged 29 and 1/4.
Re: Hi Spec
Scott,<br>
Get it in writing the cost of your Brake upgrade and the Time it's going to take to build fabricate,<br>
Don't pay the full amount on ordering pay 10% and the rest on completion.<br>
1)I waiting 18 week's for a kit and had to file the caliper's to fit Supose to be a bolt on kit B####KS,<br>
2) Mate has a twin turbo 302 AC Cobra kit car,<br>
with a Hi Spec Brake kit it keeps cracking the Disc's,<br>
Do the rules allow you to run different Disc's and Caliper's<br>
Carsreunited
Re: Hi Spec
Phil,<br>
Thanks for the info. After making my post I'd done some research on HiSpec and found a few scare stories where people had been let down and felt that HiSpec couldn't give a r4ts a4se. I'm now in two minds. <br>
As a matter of interest, what type of discs was your mate running? Grooved, Drilled or combination and were they HiSpec supplied items? The one that I read about was of calipers cracking rather than discs.<br>
I might give them a call on Monday and see what the situation is in terms of lead time. I would think that if they have a hub assembly and wheel they wouldn't be able to get it wrong so hopefully I wouldn't be having to butcher brand new anodised calipers! If they can't be done in less than 4 weeks then it looks like the Americans will be getting my money as I don't have the budget for AP or brembo stuff.<br>
The regulations are that front braking is free, Have to retain drums on the rear though. I'll have a brake bias adjuster somewhere as Mark promises me that the Rears WILL work so well I might want to be able to turn them down! Once I know the secret (and if it works!) I'll pass on the wisdom!!!<br>
Scott
Scott
Hi Spec
Scott,<br>
Spoke to Cobra owner today,<br>
Has Hi Spec suppied disc's Vented/Drilled the full work's and these have cracked up,<br>
New Disc's are machined down B.M.W. one's,<br>
Give them there due they where replaced after a long wait,<br>
Hi Spec have since moved into LARGER premies with more staff and some of the previous problem's are going,<br>
If you decide to let Hi Spec do a Brake Kit make sure you give them a Wheel and possible a complete hub assy,<br>
There's nothing worse than making something fit after you PAID someone to do it,<br>
Is the Sierra modded kit not suitable,<br>
There's plenty of people here that recommend it.
Carsreunited
HiSpec
Cheers Phil,<br>
I remember reading from some guy's website who had his Elan HiSpecced that Geoff (Head honch a HighSpec) didn't recommend Drilled as fractures became more probable????<br>
Anyway, I spoke with them today and I was told the current lead time is 28 days. I was aslo told that this was erring on the side of caution but that they are very busy due to the impending season start.<br>
As for the sierra calipers, I'm not convinced that they will be quite up to full on track use. I reckon that they are a good mod for a road use car but track use and I mean 5+Laps in one stint will result in brake fade. My wife's Mini Cooper suffered pretty soggy brakes after 4 or 5 laps at Keevil. I also think that spending £500 on decent brakes will give you at least a couple of seconds per lap advantage .<br>
The fact that the HiSpec calipers look damn sexy doesn't come into it! I just want to try something different as well. I'll definitely be taking a full hub assy down as well as standard sprint alloys and my minilites. I think my minilites can take bigger brakes according to the guy I bought them off but I want to be able to use standard sprint alloys as well. They are still a great looking wheel IMO.<br>
Scott<br>
Scott
Scott<br>
Scott
Piston Broke yet?
Scott<br>
How much were your JE Pistons??<br>
Graeme
<p><!--EZCODE LINK START--><a href="http://www.smifter1971.pwp.blueyonder.c ... >Smifter's Dolomite Sprint Website</a><!--EZCODE LINK END--></p><i></i>
Graeme
Carsreunited
JE
I don't know yet exactly how much. 600ish??<br>
Call mark as he has got about a dozen sets on order with them at the moment and should be able to give you an exact figure.<br>
Scott
Scott
Re: JE
Try TTS Performance in Silverstone. £400.<br>
Ben.<br>
Part numbers etc. on my web site.<br>
<!--EZCODE LINK START--><a href="http://www.bodgerben.com" target="top">www.bodgerben.com</a><!--EZCODE LINK END-->
Ben.<br>
Carsreunited
Re: JE
Ben,<br>
Could you give me the exact price you paid and the part numbers just so I can make sure I'm comparing like with like. I couldn't see the part numbers on your website. By the way, your site is very good, very informative.<br>
Much appreciated.<br>
Scott<br>
Scott<br>
Link
Scott,<br>
The piston part numbers etc. are here :<br>
<!--EZCODE LINK START--><a href="http://www.bodgerben.com/je-pistons11.jpg" target="top">www.bodgerben.com/je-pistons11.jpg</a><!--EZCODE LINK END--><br>
And if you find you need a different part number, TTS have one price for custom pistons £100 each (+vat)<br>
Cheers,<br>
Ben.
Cheers,<br>
Ben.
Carsreunited
Thanks Ben.
As far as I know there has been some hold up with Mark getting his pistons through from JE. It may well be if what I have on order is the same as you have then I will ask Mark to source them through TTS for my engine. He confirmed the cost to me the other day as being £750 which is significantly higher than what you have paid. I can only think that there is some difference between the two sets other than the price.<br>
I'll let you know as soon as I do.<br>
Scott
Scott
Carsreunited
Re: TTS
Me neither Phil but I suppose it stands to reason.<br>
By the way, are we still on to meet up tomorrow so that I can pick up that shock cup thing?<br>
Cheers,<br>
Scott
Cheers,<br>
Scott
Shock cap's
Scott,<br>
Yes meet somewhere listen for the Burble of the 8,<br>
If you don't see me by lunch time Give me a Bell.<br>
or I'll bell you.<br>
Re: TTS - Bikes - thats the guys...
And the chap from Jigsaw is well pissed...<br>
Sorry about that...<br>
Mind you he was quite (okay a tiny bit) happy when I said I'd buy the EWP and controller, plus a full set of bushes from him.<br>
Sorry Scott - said 'yes I'm Scott's mate' coz he's the size of a the preverbial brick xxxxhouse!<br>
(And a very nice guy, is that your lump he's talking about some serious numbers with).<br>
Ben.<br>
Ben.<br>
Carsreunited
Gulp
When you say serious numbers, do you mean cost or BHP?? Hopefully the latter.<br>
He is a top bloke as you say Ben and I would also agree takes everything in XL! <br>
I'm glad you have got some bits off of him. He's looking into the JE/TTS thing at the moment. Either way I'm going to let Mark sort it out, he knows what he is doing whereas I don't! Seems to be quite a lot of supplier politics involved if you catch my drift.<br>
Scott
Scott
