Top Fuel dragster facts......
Compiled over the years.....here's the top facts about top fuel dragsters! Fascinating stuff:<br>
I apologise as it lingers in my memory that I might have posted this before - still, it's a good read!<br>
----------------------------------------------------<br>
*One top fuel dragster 500 cubic inch hemi engine <br>
makes more horsepower than the first 4 rows at the <br>
Indy 500. <br>
*under full throttle, a top fuel dragster engine <br>
consumes I gallon of nitromethane Per second, <br>
a fully loaded 747 consumes jet fuel at the same <br>
rate with 25% less energy being produced. <br>
*a stock dodge 426 hemi v8 engine cannot <br>
produce enough power to drive the dragsters <br>
supercharger. <br>
*with 3000cfm of air being rammed in by the <br>
supercharger on overdrive, the fuel mixture <br>
is compressed into a near –solid form before <br>
ignition. the cylinders run on the verge of hydraulic <br>
lock at full throttle. <br>
*at the stoichiometric1.7:1 air/fuel mixture for <br>
nitromethane the flame front temperature <br>
measures 7050degrees F, 3800degrees C. <br>
*nitromethane burns yellow, the spectacular <br>
white flame seen above the stacks at night is <br>
raw burning hydrogen, disassociated from atmospheric <br>
water vapour by the searing exhaust gases. <br>
*dual magnetos supply 44 amps to each spark <br>
plug, this is the output of an arc welder in <br>
each cylinder. <br>
*spark plug electrodes are totally consumed <br>
during a pass, after ½ way, the engine is <br>
dieseling from compression plus the glow of <br>
exhaust valves at 1400degrees F.the engine <br>
can only be shut down by cutting of the fuel flow. <br>
*if momentarily fails early in the run ,unburned <br>
nitro builds up in the affected cylinders and <br>
then explodes with sufficient force to blow the <br>
cylinder heads off the block in pieces or split <br>
the block in half. <br>
*in order to exceed 300 in 4.5 seconds <br>
dragsters must accelerate at an average <br>
of over 4G`s.in order to reach 200mph well <br>
before half track, the launch acceleration <br>
approaches 8G`s. <br>
*dragsters reach over 300 miles per hour <br>
before you have completed reading this <br>
sentence. <br>
*top fuel engines turn 540 revolutions from <br>
light to light! <br>
*including the burnout the engine must only <br>
survive 900 revolutions under load. <br>
*the red line is actually quite high at 9500rpm <br>
*the bottom line; assuming all the equipment <br>
is paid off, the crew work for free, and for <br>
once NOTHING BLOWS UP, each run costs an <br>
estimated $1000.00 per second. the current top <br>
fuel dragster elapsed time record is 4.441 <br>
seconds for the quarter mile (05/10/03,tony <br>
Schumacher).the top speed record is 333.00mph(533km/h) <br>
as measured over the last 66` of the run,(28/9/03 doug kallita). <br>
If that hasn’t made you think enough, let’s put all this into perspective: <br>
You are riding the average $250,000 Honda motogp bike-a seriously fast machine. Over a mile up the road, a top fuel dragster is staged and ready to launch down a ¼ mile strip as you pass. <br>
You have the advantage of a flying start. you run the RC211V hard up through the gears and blast across the starting line and past the dragster at an honest 200mph (293ft/sec).the `tree` goes green for both of you at that moment. The <br>
dragster launches and starts after you. <br>
You keep your wrist cranked hard, but you hear an incredible brutal whine that sears your eardrums and within 3 seconds the dragster catches and passes you. he beats you to the finish line ,a quarter mile away from where YOU just passed him. <br>
Think about it ,from the standing start ,the dragster had a 200mph disadvantage, and not only caught ,but nearly blasted you off the road when he passed you within a mere 1320 foot long drag strip.<br>
One I found out later too, is that how if one bank of the V8 fails, the resulting loss of downforce from the exhausts on that bank is enough to make the dragster veer off course. Bonkers! <!--EZCODE EMOTICON START :smokin --><img src=http://www.ezboard.com/images/emoticons/smokin.gif ALT=":smokin"><!--EZCODE EMOTICON END-->
<!--EZCODE FONT START--><span style="font-size:xx-small;"><!--EZCODE ITALIC START--><em>Crazy! I mean like so many positive waves, we can't lose! You're on!</em><!--EZCODE ITALIC END--></span><!--EZCODE FONT END--></p><i>Edited by: <A HREF=http://p206.ezboard.com/bthetriumphdolo ... >LewisK</A> at: 30/8/06 3:45 pm<br></i>
Indy 500. <br>
supercharger. <br>
each cylinder. <br>
sentence. <br>
dollysteve
Re: Top Fuel dragster facts......
Engine blocks are also made from Billet Ally and run without coolant.<!--EZCODE EMOTICON START :) --><img src=http://www.ezboard.com/images/emoticons/smile.gif ALT=":)"><!--EZCODE EMOTICON END-->
The tyres expand as they reach rotational speed increasing their circumference and so the distance travelled per engine revolution. The tyres are the only 'gearbox' on a TFD.<br>
Tinweevil
<p>1978 <!--EZCODE LINK START--><a href="http://www.triumphowners.com/704">Dolomite Sprint</a><!--EZCODE LINK END--> Blue, a bit tetley. - Current daily drive.<br>
1980 <!--EZCODE LINK START--><a href="http://www.triumphowners.com/864">Dolomite 1500HL</a><!--EZCODE LINK END--> Orange, really quite tidy.</p><i></i>
Tinweevil
Top fuel dragsters
I was at Santa Pod about 18/19 years ago and witnessed a TFD attempting to break the european record which at the time was sub 5 second. From the moment it took off it looked in trouble, veering to the side all the way up the strip, however the driver/pilot kept it going full chat until it hit the side just before the finish and disintegrated. The silence in what was a large crowd was eerie. It was a pretty shocking thing to see and almost sureal. I think some of the parts ended up 1/4 mile past the finish. The driver survived just, but broke his back and lost an arm. Will never forget it
top drag bike
what about the other crazy frog who jumps on a jet bike <!--EZCODE EMOTICON START :eek --><img src=http://www.ezboard.com/images/emoticons/eek.gif ALT=":eek"><!--EZCODE EMOTICON END-->
Re: top drag bike
Rocket car man Sammy Millar used to drive with his head to the side due to the G force and eventually stopped driving because his teeth were falling out !. <br>
If i remember right he did approx 330 mph in 3.5 seconds.<br>
Re: top drag bike
<!--EZCODE QUOTE START--><blockquote><strong><em>Quote:</em></strong><hr>You are riding the average $250,000 Honda motogp bike-a seriously fast machine. Over a mile up the road, a top fuel dragster is staged and ready to launch down a ¼ mile strip as you pass. <hr></blockquote><!--EZCODE QUOTE END--><br>
etc etc...<br>
just to support the biker fraternity, with perhaps a silly twist to show you cant actually use this as any sensible comparison as the machines are built for a completely different purpose (advocate of <!--EZCODE EMOTICON START :evil --><img src=http://www.ezboard.com/images/emoticons/devil.gif ALT=":evil"><!--EZCODE EMOTICON END--> ) :<br>
they decided to host this experiment on a stretch of the M1. unfortunately, while in real life terms this is generally a relatively straight road, we do still have to pity the dragster. after the dragster with maybe 10 times the hp of the bike went whooping past at around 1.5 times the speed, they reached a small curve in the road, hardly noticeable at 70-80 mph, but at 3 times that speed its a bit more significant. the dragster had no practical way of stopping in a controlled manner, hit the barrier, smashed into a squillion pieces, exploding into a horrendous fireball killing the driver and 5 onlookers instantly, while the honda rider, while mildy embarrassed at being overtaken a few seconds before, gently applied his BRAKES, leaned over a bit and negotiated the blaze and parts strewn around everywhere, and made it home in time for tea.<br>
DOH!<br>
<!--EZCODE EMOTICON START :rollin --><img src=http://www.ezboard.com/images/emoticons/roll.gif ALT=":rollin"><!--EZCODE EMOTICON END-->
etc etc...<br>
DOH!<br>
biker
and as he turned into his road on his way home a<br>
car knocked him right off his bike (he didn't see him )<br>
and his bike is now in a squillion pices too !!!! <!--EZCODE EMOTICON START :rollin --><img src=http://www.ezboard.com/images/emoticons/roll.gif ALT=":rollin"><!--EZCODE EMOTICON END-->
Re: biker
<!--EZCODE EMOTICON START :rollin --><img src=http://www.ezboard.com/images/emoticons/roll.gif ALT=":rollin"><!--EZCODE EMOTICON END--> like it george, sad but unfortunately close to the truth...<br>
'borrowed' this from the superbike forum I go on, quite deep and makes you think:<br>
I saw you,<br>
hug your purse closer to you in the grocery store line.<br>
But, you didn't see me,<br>
put an extra £10.00 in the collection plate last Sunday.<br>
I saw you,<br>
pull your child closer when we passed each other on the sidewalk.<br>
playing Santa at the local mall.<br>
I saw you,<br>
change your mind about going into the restaurant.<br>
attending a meeting to raise more money for the hurricane relief.<br>
I saw you,<br>
roll up your window and shake your head when I drove by.<br>
driving behind you when you flicked your cigarette butt out the car window.<br>
I saw you,<br>
frown at me when I smiled at your children.<br>
when I took time off from work to run toys to the homeless.<br>
I saw you,<br>
stare at my long hair.<br>
and my friends cut ten inches off for Locks of Love.<br>
I saw you,<br>
roll your eyes at our leather coats and gloves.<br>
and my brothers donate our old coats and gloves to those that had none.<br>
I saw you,<br>
look in fright at my tattoos.<br>
cry as my children where born and have their name written over and in my heart.<br>
I saw you,<br>
change lanes while rushing off to go somewhere.<br>
going home to be with my family.<br>
I saw you,<br>
complain about how loud and noisy our bikes can be.<br>
when you were changing the CD and drifted into my lane.<br>
I saw you,<br>
yelling at your kids in the car.<br>
pat my child's hands, knowing he was safe behind me.<br>
I saw you,<br>
reading the newspaper or map as you drove down the road.<br>
squeeze my wife's leg when she told me to take the next turn.<br>
I saw you,<br>
race down the road in the rain.<br>
get soaked to the skin so my son could have the car to go on his date.<br>
I saw you,<br>
run the yellow light just to save a few minutes of time.<br>
trying to turn right.<br>
I saw you,<br>
cut me off because you needed to be in the lane I was in.<br>
leave the road.<br>
I saw you,<br>
waiting impatiently for my friends to pass.<br>
But, you didn't see me.<br>
I wasn't there.<br>
I saw you,<br>
go home to your family.<br>
Because, I died that day you cut me off.<br>
I was just a biker,.....<br>
A person with friends and a family.<br>
BUT, YOU DIDN'T SEE ME
I saw you,<br>
I saw you,<br>
I saw you,<br>
I saw you,<br>
I saw you,<br>
I saw you,<br>
I saw you,<br>
I saw you,<br>
I saw you,<br>
I saw you,<br>
I saw you,<br>
I saw you,<br>
I saw you,<br>
I saw you,<br>
I saw you,<br>
leave the road.<br>
I saw you,<br>
I wasn't there.<br>
I saw you,<br>
dollysteve
Makes me think....
About the tosser on his BMW RT1200 this morning overtaking me on a tight country road approaching a corner and then cutting me up so he could get round without colliding with an on coming van, why is that so many bikers feel that they can overtake people whenever an whereever they please and car drivers should just accept it and put the brakes on. I agree that there are too many car drivers that don`t see bikers and it`s in-excusable but equally there are awful lot of bikers who put themselves and car drivers in danger just so they can squeeze past one car length, bikers are all too quick to blame car drivers but I wouldn`t mind betting that they ride around like tossers.<br>
Oh and I speak as a rider and driver......<br>
I`m done now, the above mentioned tosser really got on my nerves..
Re: Makes me think....
likewise steve, as a biker/driver i have to say there's a minority of biker morons who ride like idiots, too close to 4+wheeled traffic, overtake in daft situations etc and unfortunately give bikers a bad reputation.<br>
I also reckon theres an equal proportion of idiot car drivers out there, I see them every day, eg last night on the way home in the wet, I was doing about 85-90 down the A52 into derby, sat in outside lane coming up to overtake a car about maybe 40-50metres in front but on the inside line... pair of HID headlights appeared in my mirror, undercut me, distance between me and the other car had closed to about 10metres and this tw@t in his audi TT undercut me nearly landing up the @rse of the car on the inside lane, then cut me up when he pulled back into my lane, doing at least 100. whats the point in that? did he think he looked good? about half a mile later I pulled up along side him at the lights on the pentagon roundabout... didnt get very far did he...<br>
a few weeks ago I was going down the M1 just south of J21, doing a steady 90 or so, along came a little gathering of junior pimp my riders in corsas, saxo's etc, about 6 of them, absolutely flat out over all 3 lanes, overtaking eachother n weaving about all over the place. while I could have left them all behind I didnt engage, just left them to carry on. <br>
Morons.<br>
not just bikers m8<br>
Morons.<br>
dollysteve
<!--EZCODE QUOTE START--><blockquote><strong><em>Quote:</em></strong><hr>not just bikers m8<hr></blockquote><!--EZCODE QUOTE END--><br>
Couldn`t agree more, it`s just that it happened to be a biker that tried to kill me/himself today and the passage you dropped in made me think how much I hate people like that.<br>
With regards TT drivers. I have to say that after having worked as VW/Audi technician and been out on many roadtests with a TT drivers for various faults I can confirm that all of them have driven like complete tossers, this makes me think that it`s an epedemic across the country with anyone that owns one of these most dull boring cars. Perhaps they feel they need to make up for certain in-adequacies.<br>
BMW Motorcyle, Audi TT.....<br>
Seems that anyone in a German motor has the right to drive like a total tosser. Let them get on with it, keep out of their way, stay calm and be safe in the knowledge that you're the better driver. They'll be statistics sooner than you if you stay aloof and concentrate on keeping yourself safe and legal.<br>
'Everyone going slower than you is an obstruction, everyone going faster is a lunatic'<br>
Jod
Jod
