missing petrol cap key!!
hi there...i am a virgin dolly 1850 automatic owner, beautiful car, very clean with only 47k on clock! however, its not likely to increase as i cant get the petrol cap off....no key and the other 2 i have(doors and boot) dont seem to fit. the lady that owned it (2nd owner) is 92 and hasnt used it for 2 years apart from to have it mot'd and is a bit batty, bless her, so not much help.<br>
What should i do????? also, what is the best juice to use, should i put super unleaded in or use a mix?? not experienced at all this so be gentle with me,<br>
much appreaciated,<br>
sahxxx
sahxxx
Carsreunited
Re: missing petrol cap key!!
Hi there. Lore has it that 1850's are fine with regular 95 ron unleaded.<br>
I had the same predicament with a Chrysler Voyager at a petrol station last month. In the end, I bought a screwdriver and jammed it into the keyhole. A few seconds of wriggling it about, it turned and came off. I'd suggest a similar tactic for you.<br>
Welcome to the board. Free advice is a speciality here!<br>
Scott
Scott
Is the cap lumpy black plastic or shiny metal?
thanks for the replies folks! it is a lumpy black one! im not too worried about 'breaking and entering' as long as i dont do anything that will hurt the poor beast. although, if i can get a key then so much the better....<br>
thanks for the petrol info too. backs up what she said. <br>
xxsahxx
xxsahxx
PurpleBargeKen
Yep, screwdriver works just fine. If you want a replacement they come up on ebay on a fairly regular basis. Good luck and welcome to the fold.<br>
Ken
Ken
all sorted...many thanks you lot!!<br>
sahxx
sahxx
As for the fuel, it does depend on what has been put in there previously. If it's been set up properly to run on normal unleaded (there are a couple of adjustments needed under the bonnet to ignition timing and the carburettors, but nothing major at all) there probably won't be a problem with it unless you do a lot of miles, in which case there are additives that you can buy to help. Personally I use super in my Sprint (when it works) but that's because I do a lot of motorways. Avoid LRP if it's still available, the general consensus is that it doesn't do the engine too much good.
