worth it?
worth it?
<!--EZCODE AUTOLINK START--><a href="http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... <!--EZCODE AUTOLINK END--><br>
Mooching around the bay and a few quid in the paypal.
dollysteve
Re: worth it?
I have got the Jigsaw column coupling on my 1850 and it`s perfect, it goes straight on with no dramas, well worth the investment which happens to be cheaper than the standard floppy OE part. I did talk to them about solid rack mounts and was basically told that so long as you are using standard size wheels and tyres and nothing low profile, even for road use they are good and not too harsh. I have bought a set so will let you know how they go when work resumes on the 1850 which should be soon now the garden and drive way are done.
<p>1976 Dolomite 1850 HL<br>
1979 Dolomite 1500<br>
1989 Mini 1340 Race Car<br>
1998 Fiat Bravo TD100</p><i></i>
le-mans = jisgaw
so ebay user le-mans is Jigsaw?
dollysteve
Re: worth it?
Yup<!--EZCODE EMOTICON START :rollin --><img src=http://www.ezboard.com/intl/aenglish/im ... s/roll.gif ALT=":rollin"><!--EZCODE EMOTICON END-->
Re: worth it?
You can get the coupling cheaper from Rally Design...just over 20 quid IIRC.<br>
Martin
<p><!--EZCODE LINK START--><a href="http://www.dolomitesprint.com/" target="top">www.dolomitesprint.com</a><!--EZCODE LINK END--></p><i></i>
Martin
dollysteve
Re: worth it?
I originally had one from Rally Design but it was the cast type and not the pressed steel one and wouldn`t fit properley, the Jigsaw one is made for the job and reqires no mods to fit as some people have reported with the Escort one although equally some have reported that no mod was needed.
Re: worth it?
Are those rack mounts worth buying? Have got some new poly bushes & wondering if would be worth replacing mounts.<br>
Jeff
Jeff
Re: worth it?
You don't need a pair, one on the driver's side is what used to be recommended; the plate locates the rack on the other side with the standard arrangement.<br>
Team up guys and halve the cost
<p>1973 Dolomite Sprint<br>
1974 Dolomite Sprint<br>
1977 Dolomite Sprint<br>
1979 Dolomite Sprint<br>
1980 Dolomite 1500HL<br>
1998 Lotus Elise<br>
1999 Alfa Romeo 166</p><i></i>
Re: Coupling
My Rally Design Steering coupling arrived yesterday.<br>
And looks the same as the Jigsaw one,<br>
<p>1980 Dolomite Sprint V8.(To be MegaSquirted watch this space)<br>
1996 Rover 115 (Diesel and with a leaking displacer)<br>
2003 Suzuki GSX1300R (90mph in 1st gear Someone should of said it was 6 Speed)</p><i></i>
Re: Coupling
dollysteve, so you didn't have to do any mods to yours..not even shortening the shaft by ½" ?<br>
Martin
Martin
dollysteve
Re: Coupling
No, didn`t have to do any mods. I used the same method as Richard used on his 1500`s, no probs at all.
Users browsing this forum: No registered users and 6 guests
