Polishing alloy wheels
balcksprint
magnesium oxide
#16 Post by balcksprint » Fri Oct 07, 2005 8:26 pm
Help! I'm confused I thought the wheels are aluminum alloy, not magnesium. Please forgive me if I'm being simple.<br>
Neil<br>
Ps. Is the only way to put pictures on is to have some webspace.
2F45T4U
Re: magnesium oxide
#17 Post by 2F45T4U » Fri Oct 07, 2005 8:52 pm
http://www.shutterfly.com<br>
FREE! sign up and bombard us with lots of pictures of dolomites. <!--EZCODE EMOTICON START :D --><img src=http://www.ezboard.com/intl/aenglish/im ... /happy.gif ALT=":D"><!--EZCODE EMOTICON END-->
redrichie
Re: magnesium oxide
#18 Post by redrichie » Fri Oct 07, 2005 8:53 pm
nope, i use Imageshack....<br>
<!--EZCODE LINK START--><a href="http://www.imageshack.us/" target="top">Imageshack</a><!--EZCODE LINK END-->
blacksprint
Re: magnesium oxide
#19 Post by blacksprint » Fri Oct 07, 2005 10:08 pm
Hoorah!!! I did it. Sorry about the cameraphone quality. I last polished it a few months back, but it's only been out of the garage a few times to do some work.<br>
Neil<br>
<!--EZCODE IMAGE START--><img src="http://im1.shutterfly.com/procserv/47b5 ... QZsmzls5cq" style="border:0;"/><!--EZCODE IMAGE END-->
alun n
Re: magnesium oxide
#20 Post by alun n » Sat Oct 08, 2005 2:46 am
Yup, aluminium alloy with a high percentage of magnesium and a bit of nickel. <br>
Aluminium oxide will form, but that then creates a protective coat of aluminium oxide which prevents further oxidisation of the aluminium; aluminium oxide is stronger than aluminium. <br>
Magnesium oxide however continues to be formed and is partly why old wheels leak; as the magnesium degrades they go pourous!
MalcGE
Micromesh
#21 Post by MalcGE » Sat Oct 08, 2005 9:22 am
So where does one get this magical micromesh from?<br>
The results certainly look good <!--EZCODE EMOTICON START :D --><img src=http://www.ezboard.com/intl/aenglish/im ... /happy.gif ALT=":D"><!--EZCODE EMOTICON END-->
Stan Part
Re: Stickys
#22 Post by Stan Part » Sat Oct 08, 2005 11:08 am
Adam they came from here :<br>
<!--EZCODE AUTOLINK START--><a href="http://www.speeding.co.uk/acatalog/Perm ... <!--EZCODE AUTOLINK END--><br>
Hey, looks pretty good <!--EZCODE EMOTICON START ;) --><img src=http://www.ezboard.com/intl/aenglish/im ... s/wink.gif ALT=";)"><!--EZCODE EMOTICON END-->
2F45T4U
Re: Stickys
#23 Post by 2F45T4U » Sat Oct 08, 2005 11:20 am
Must resist buying any.... Ill have spoilers and all sorts on my car before long <!--EZCODE EMOTICON START :lol --><img src=http://www.ezboard.com/intl/aenglish/im ... /laugh.gif ALT=":lol"><!--EZCODE EMOTICON END--> jk <!--EZCODE EMOTICON START :| --><img src=http://www.ezboard.com/intl/aenglish/im ... ferent.gif ALT=":|"><!--EZCODE EMOTICON END-->
blacksprint
Re: micromesh
#24 Post by blacksprint » Sat Oct 08, 2005 1:51 pm
In answer to your question Malc this link should sort you out. I use it at work for finishing the compressor blabes on the aircraft engines. I started with 1800 grade then 3200 both with wd40 (keep it wet). Then wipe over clean, and finally a quick go over with autosol or something similar. My wheels were quite clean but by no means great but if there realy bad I would sugest that some heavy duty scotchbrite or wet&dry to start with. <!--EZCODE AUTOLINK START--><a href="http://www.ss-sci.com/Micromesh.PDF">ww ... <!--EZCODE AUTOLINK END-->
redrichie
Re: micromesh
#25 Post by redrichie » Sat Oct 08, 2005 2:26 pm
I use it for taking scratches out of aircraft windscreens at work....as far as i know, its quite expensive to buy, but after having seen Blacksprints picture...the results look amazing.<br>
richie
redrichie
one down, four to go
#26 Post by redrichie » Tue Nov 08, 2005 11:14 am
The wonders of micromesh™<br>
<!--EZCODE IMAGE START--><img src="http://img368.imageshack.us/img368/1017 ... <!--EZCODE IMAGE END--><br>
<!--EZCODE IMAGE START--><img src="http://img368.imageshack.us/img368/3713 ... <!--EZCODE IMAGE END--><br>
<!--EZCODE IMAGE START--><img src="http://img359.imageshack.us/img359/4783 ... <!--EZCODE IMAGE END--><br>
only four more to go....and remember guys, lacquering them only makes it harder to polish next time. "Bring out the Dremel...."<br>
sorry about the size of them, but i am rubbish at paintshop...<!--EZCODE EMOTICON START :rollin --><img src=http://www.ezboard.com/intl/aenglish/im ... s/roll.gif ALT=":rollin"><!--EZCODE EMOTICON END-->
FVC dolly
Re: one down, four to go
#27 Post by FVC dolly » Tue Nov 08, 2005 12:08 pm
Richie,<br>
Looks very good that, can the MOD supply some micromesh for me?<!--EZCODE EMOTICON START :D --><img src=http://www.ezboard.com/intl/aenglish/im ... /happy.gif ALT=":D"><!--EZCODE EMOTICON END--> <br>
Cheers<br>
Jeff
<p>1979 Dolomite 1300</p><i></i>
redrichie
actually
#28 Post by redrichie » Tue Nov 08, 2005 2:20 pm
I used normal 320 grade wet and dry, with lots of WD-40. The micromesh was just a quick rub over at the end. I reckon an acceptable finish could be had by using 1600 grade, available at any B&Q. I wanted to finish it with Autosol, but couldn't find any, so household brasso was the final touch.<br>
I cannot stress enough though, after spending one whole morning just removing the lacquer from the second wheel, lacquer is the spawn of satan and must be kept as far away from these wheels as possible, preferably in another galaxy. <!--EZCODE EMOTICON START :evil --><img src=http://www.ezboard.com/intl/aenglish/im ... /devil.gif ALT=":evil"><!--EZCODE EMOTICON END-->
2F45T4U
Re: actually
#29 Post by 2F45T4U » Tue Nov 08, 2005 3:55 pm
my wheels look incredibley crummy already! Will a good polish keep the crud away? <br>
At the restore show a man was telling me and my mate that he used a light oil to coat the wheels with instead of laquer.<br>
Adam
davepoth
Re: actually
#30 Post by davepoth » Tue Nov 08, 2005 4:17 pm
There is one, I think made by Wurth, that has all the properties of wd40 but is a bit heavier and sticky which my old mechanic used to use on everything that wasn't covered in copper grease.
Locked
