low rev misfire<br>
--------------------------------------------------------------------------------<br>
Well I have changed nothing besides the rotor arm and this was from my other dolly sprint which is running fine. Plugs seem fine checked the gap etc. checked each HT lead and there was spark on each. She has electronic ignition.<br>
At times at idle she can seem a bit rough then clear, when trying to pull away from traffic lights "sometimes" she will miss so bad that it sounds to be running on 2 cylinders and no power, rev her up a bit she then clears and off she goes.<br>
Thanks Jack
Low Rev Misfire
