electronic ignition
Locked
gogs1911
electronic ignition
#1 Post by gogs1911 » Tue Aug 15, 2006 12:50 am
Don't shoot, but I would like to know if it's worthwhile fitting an electronic ignition to my Sprint, if so what the best type to go for or should I stick with what I've got.<!--EZCODE IMAGE START--><img src="http://im1.shutterfly.com/procserv/47b6 ... QctHDZqzYg" style="border:0;"/><!--EZCODE IMAGE END-->
DailySprinter
electronic ignition
#2 Post by DailySprinter » Tue Aug 15, 2006 7:50 am
I would'nt use anything else, the quality of condensers is so poor now. I use a pirannha one, it's fine. Runs much smoother too
redrichie
Re: electronic ignition
#3 Post by redrichie » Tue Aug 15, 2006 8:17 am
Yup, I use a Newtronic one. Fairly straightforward to fit, and takes out the whole mess around factor of points and condensors. Go for it. <!--EZCODE EMOTICON START ;) --><img src=http://www.ezboard.com/images/emoticons/wink.gif ALT=";)"><!--EZCODE EMOTICON END-->
dollybird72
Electronic Ignition
#4 Post by dollybird72 » Tue Aug 15, 2006 9:12 am
I had it fitted to my 1500HL - it was one manufactured by Jod and he fitted it for me.<br>
I would definitely recommend one and will be having one fitted to Victor too.<br>
As the switch is in the glove box, it also acts as an immobiliser when in the 'off' position which is a great added bonus (except when you forget you've switched it off and think the car won't start!) <!--EZCODE EMOTICON START :lol --><img src=http://www.ezboard.com/images/emoticons/laugh.gif ALT=":lol"><!--EZCODE EMOTICON END--> <br>
Susie
<p></p><i>Edited by: <A HREF=http://p206.ezboard.com/bthetriumphdolo ... ybird72</A> at: 15/8/06 9:13 am<br></i>
alun n
#5 Post by alun n » Tue Aug 15, 2006 9:13 am
Jod Clark makes and sells a unit which does away with the condensor but keep the points but gives a cleaner stronger spark; both Susie and I have these fitted and it shows a marked difference in starting and fuel economy.
I might
#6 Post by Jon Tilson » Tue Aug 15, 2006 9:29 am
be tempted by a couple of Jod specials Alun, especially if you or he emailed me with details of how to order, pay and likely timescales...<br>
Jonners<br>
Leeds Sprint
Electronic Ignition
#7 Post by Leeds Sprint » Tue Aug 15, 2006 1:53 pm
I'm pretty happy with my Lumnetronic set up. It's definatly helped smooth out performance accross the range.
Jod Clark
Re: Electronic Ignition
#8 Post by Jod Clark » Tue Aug 15, 2006 1:59 pm
oooooo lovely lovely electronic ignitions <!--EZCODE EMOTICON START :) --><img src=http://www.ezboard.com/images/emoticons/smile.gif ALT=":)"><!--EZCODE EMOTICON END--> <br>
The ones I make are dead easy to fit, lose the condensor and connect just 4 wires. They even come with the appropriate connectors on the ends of the correct-length cables. The are proving reliable in the extreme.<br>
schmurg3n@hotmail.com is where I'll be from today....<br>
Jod<br>
Jod Clark
#9 Post by Jod Clark » Sat Aug 19, 2006 9:47 am
I'm planning to take ten or so of these units to TDCIR to offer for sale or just talk about with anyone interested. I know two units already have names on them, how many more?<br>
I should have mentioned that cable-ties and full fitting instructions are included.<br>
My 1300 has had one fitted for over 10000 miles now. When I first changed over to this EI unit (the first one) it made a 5MPG improvement. I can't guarantee how big the improvement will be on <!--EZCODE ITALIC START--><em>your</em><!--EZCODE ITALIC END--> car, but it will not be subtle! Starting and high-rev performance is considerably better too.<br>
In 10000 miles the points gap has not altered AT ALL from the original setting.<br>
drop me an email on the above address if you would like to know more....<br>
Jod<br>
mbellinger
#10 Post by mbellinger » Mon Aug 21, 2006 9:51 am
Jod,<br>
Baggsie two for me please! Not greedy but two cars (1 x 1300, 1 x 1500). I'll text you or e mail off post.
<p>Martin<br>
1968 Triumph 1300FWD<br>
1975 Triumph 1500TC Auto<br>
1989 Honda Civic 1300 Auto<br>
2006 Mondeo 2.0 Ghia X Auto<br>
2002 Renault Scenic<br>
</p><i></i>
Sprint36
Maintenance
#11 Post by Sprint36 » Mon Aug 21, 2006 10:48 am
Note of advice here. Just because your points don't need any maintenance, you still need to check the rotor arm and cap occasionally. With the optical type the pickup can still get crap on it and give a poor signal too. It's easy to neglect this stuff when the points don't need adjusting anymore. <br>
David
rpgrainger
electronic ignition
#12 Post by rpgrainger » Mon Aug 21, 2006 6:32 pm
Jod<br>
i have emailed you aswell<br>
Cheers<br>
Rob
Locked
