Dwell Angle
Karl1850
Dwell Angle
#1 Post by Karl1850 » Fri Sep 22, 2006 6:55 pm
I have borrowed a dwell meter from a chap across the road, so I just gave it a go. My Autobook for the 1850 says the dwell angle is 40 degrees +/-1 degree. The best I can get is about 25 degrees any more and the points don't open any more. I put on new points, condenser, leads and started off setting the points with feelers. Anyone know if 40 degrees is correct for an 1850 or have I got a dogdgy set or something else?
dollyboy
Re: Dwell Angle
#2 Post by dollyboy » Fri Sep 22, 2006 8:41 pm
best not to dwell on it...<br>
<!--EZCODE EMOTICON START :| --><img src=http://www.ezboard.com/images/emoticons/indifferent.gif ALT=":|"><!--EZCODE EMOTICON END--> <br>
<!--EZCODE EMOTICON START :lol --><img src=http://www.ezboard.com/images/emoticons/laugh.gif ALT=":lol"><!--EZCODE EMOTICON END-->
rich
Re: Dwell Angle
#3 Post by rich » Fri Sep 22, 2006 8:49 pm
bought a dizzy off someone with an " advanced curve ".<br>
now me misses has some of these but can anyone explain what its about..
Karl1850
Re: Dwell Angle
#4 Post by Karl1850 » Fri Sep 22, 2006 11:12 pm
Dunno what the dwell is all about to be honest. Something to do with the number of degrees of rotation of the crank or maybe the rotor arm that the points are open or shut?<br>
Any dwellberts out there know any better?
<p></p><i>Edited by: <A HREF=http://p206.ezboard.com/bthetriumphdolo ... arl1850</A> at: 22/9/06 11:13 pm<br></i>
george
dwell
#5 Post by george » Fri Sep 22, 2006 11:44 pm
the dwell angle is 39 deg +/- 1 deg and unless you have a meter you cannot check it just adjust your points correctly and your dwell will be o.k<br>
Karl1850
Re: dwell
#6 Post by Karl1850 » Sat Sep 23, 2006 10:56 am
I think I'll take DollyBoy's advice and not dwell on it.
ALG1K
Re: dwell
#7 Post by ALG1K » Sat Sep 23, 2006 10:00 pm
Dont dwell on it and bin the points
rich
Re: dwell
#8 Post by rich » Sat Sep 23, 2006 10:03 pm
any idea what the advance cure is about daz<br>
rich
Re: dwell
#9 Post by rich » Sat Sep 23, 2006 10:14 pm
or may be its the same thing i dont know??????????????????????
george
dwell
#10 Post by george » Sat Sep 23, 2006 10:48 pm
it's advance curve not cure
MalcGE
Re: dwell
#11 Post by MalcGE » Sun Sep 24, 2006 7:25 pm
IIRC to increase the dwell you close the points. Its one of those things that I have to refresh myself on. But as points wear, the gap closes, the dwell increases and the ignition timing retards.
rich
Re: dwell
#12 Post by rich » Sun Sep 24, 2006 7:30 pm
sorry george , to much wine! again<!--EZCODE EMOTICON START :D --><img src=http://www.ezboard.com/images/emoticons/happy.gif ALT=":D"><!--EZCODE EMOTICON END--> <br>
Karl1850
Re: dwell
#13 Post by Karl1850 » Sun Sep 24, 2006 9:04 pm
Maybe the heel on my "new" points is too short. To get a big enough gap to give me 39 degrees of dwell I close the gap so far but then the dizzy cam misses the heel and doesn't open the points at all.<br>
Or maybe I am just being fooled (not the first or last time <!--EZCODE EMOTICON START :rolleyes --><img src=http://www.ezboard.com/images/emoticons/eyes.gif ALT=":rolleyes"><!--EZCODE EMOTICON END--> ) by a crappy old Gunsons dwell meter. Anyway I have set the points using feelers and timed the engine with a strobe and it seems good enough for now - at least it starts on the first attempt.
<p></p><i>Edited by: <A HREF=http://p206.ezboard.com/bthetriumphdolo ... arl1850</A> at: 24/9/06 9:05 pm<br></i>
Stephen Grellet
Dwell angle
#14 Post by Stephen Grellet » Sun Sep 24, 2006 9:59 pm
The dwell angle is the time the points stay closed, which is the amount of time the coil has to re-energize between ignition firings. Too shorter dwell time (angle) and the coil may not re energise sufficiently.
the points
#15 Post by Jon Tilson » Mon Sep 25, 2006 12:26 am
On an 1850 with delco dizzie the points can be adjusted both ends cos both securing screws have a slottted hole so you shoukd be able to get it close enough to still opne on the cam withy a 15 thou gap.<br>
Locked
